ZC wiring harness?
Old Apr 26, 2004 | 06:30 PM
Dspad_91Civic's Avatar
Default ZC wiring harness?
I'm guessing since the ZC came from Japan that it would be near impossible to find a wiring harness for it if it didnt come with the engine? Or can I use another wiring harness?
Old Apr 26, 2004 | 06:51 PM
jlicrx's Avatar
Default Re: ZC wiring harness? (Dspad_91Civic)
you need to use the engine wiring harness for your car and make any necessary wiring changes to it - harnesses are not interchangeable, DX must use DX, Si must use Si, etc. - you can rob any connectors you might need from the ZC harness
BIG RICH's Avatar
you can make one. Use an 88-91 Si harness, but I think you have to swap the distributor plugs to square ones. like the DX's have.
Old Apr 26, 2004 | 06:55 PM
Default Re: ZC wiring harness? (BIG RICH)
Is there anywhere I can go to get the facts on this? Anyone else hear about using an si harness?
Old May 7, 2004 | 03:06 PM
nikitad's Avatar
In what car? As it was said before, it's easy to adapt an SI harness to run a ZC in SI, and easy to adapt HF harness to run a ZC in HF.
Just distro plugs have to be changed.
It's more labor for DX'es though.
What is your particular situation?
Old May 7, 2004 | 05:12 PM
zcrxt's Avatar
Go to thezcr.com
Everything you need to know about your zc!
88crxdxfastwhip
Nov 3, 2005 06:46 AM
CRXsiproject
Oct 10, 2005 08:38 PM
RussHondaCRXVtec
May 12, 2003 08:16 PM
vtec_head
May 8, 2002 08:59 AM
JDM HYBRID
Mar 22, 2002 02:57 PM
