Comptech sway-bar w/LTB
Old Oct 31, 2001 | 10:05 PM
WykidEH's Avatar
Default Comptech sway-bar w/LTB
Is anyone running the Comptech rear sway-bar(22mm) w/the lower tie bar for a Integra on a '92-up Civic HB? If so, what're the ups and downs of using a 22mm bar? DO you like it? I'm thinking of doing it. People are using the ITR rear sway-bar on thier Civic HB's(22mm). Do you all like it? Isn't it thwe same?
Old Nov 1, 2001 | 12:05 PM
johng's Avatar
Default Re: Comptech sway-bar w/LTB (WykidEG6)
I have the three way adjustable unit for the Integra and it's a great bar. I've used it for the last few races and really like it.
I think I can russle up a few pictures if you're interested.
Old Nov 1, 2001 | 12:12 PM
C1V1C's Avatar
Default Re: Comptech sway-bar w/LTB (johng)
I'm using the ITR rear swaybar and its great, no complaints, haven't been on the track since I got it but theres a big difference taking highspeed corners, the car stays flat.
Old Nov 1, 2001 | 09:27 PM
WykidEH's Avatar
Johng, I would like to see pics if you have some. . . .
Old Nov 2, 2001 | 12:01 AM
mafay2's Avatar
New User
It was a hot item when it first came out, because it seem like this combo solve the problem of bigger swaybar ripping out the sub-frame. For some reason, not too many people mention about it lately. I would say it is one of the best sway bar out there and you wouldn't have to worry about ripping out the sub-frame with it. If you have the $$, get it!!
Old Nov 2, 2001 | 11:55 AM
johng's Avatar
I'm using GSR LCA's. This is the best bar I've used, or seen.
Old Nov 3, 2001 | 07:39 AM
TodaSi's Avatar
So, to use the Comptech bar on a 92-95 all you need are the GS-R lower control arms? Then you use the GS-R 94-01 kit? Cool!
Old Nov 3, 2001 | 01:28 PM
WykidEH's Avatar
Default Re: Comptech sway-bar w/LTB (TodaSi)
That's right! and i already have a Delsol dohc rear sway-bar and lca's. . . .
Old Nov 3, 2001 | 01:58 PM
SpecR_EK's Avatar
New User
I'm using the ST kit thats basically the same as the comptech one. Car is vary stable and made a huge difference with my entry and exit speeds on corners.
Old Nov 4, 2001 | 09:46 AM
pagong's Avatar
Default Re: Comptech sway-bar w/LTB (SpecR_EK)
will i be able to fit a full 3" exhaust with those setups? I would really like to get the sway bar kit from ST. any info would be nice .. .
Old Nov 5, 2001 | 12:43 AM
SpecR_EK's Avatar
New User
Default Re: Comptech sway-bar w/LTB (pagong)
you should, the endlink is adjustable and you should be able to move it away from the exhuast if your car is lowered.
Linh.
Suspension & Brakes
Mar 29, 2006 09:24 PM
Seedc2
Jun 13, 2003 12:58 AM
WykidEH
Nov 1, 2001 05:05 PM
