will RC injectors with resistor box work with obd1 dizzy swap work together
Old Apr 26, 2004 | 05:27 PM
darkdemon215's Avatar
Default will RC injectors with resistor box work and obd1 dizzy swap work together
i have a 88 crx si with obd1 dizzy and hondata ecu p28 , rc injectors (high independence which needs the resistor box) will they all work together?
Modified by darkdemon215 at 3:21 AM 5/6/2004
Old May 5, 2004 | 06:23 PM
Default Re: will RC injectors with resistor box work and obd1 dizzy swap work together (darkdemon215)
can any one help me?
Old May 5, 2004 | 06:35 PM
HamiltonRex's Avatar
yeah man
isnt obd0 like 4.5V and obd1 12V for the injectors, ECU always sends 12V but with obd0 resistor box lowers to 4.5V.
You can mix and match injectors as long as you use the box if needed.
-Eric
Old May 5, 2004 | 06:54 PM
Default Re: will RC injectors with resistor box work and obd1 dizzy swap work together (HamiltonRex)
thanks
Randysi
Apr 4, 2012 10:17 AM
surkitroller
Dec 29, 2009 12:58 PM
e jay one
Aug 6, 2005 02:48 PM
mr. Grind
Aug 15, 2004 12:13 PM
