CALLING ALL JDM ENGINES!!!!!!! HOW DID YOU WIRE YOUR 4 WIRE O2 SENSOR TO TAKE AWAY CEL
Old Apr 26, 2004 | 01:39 PM
JusT a Cx's Avatar
Default CALLING ALL JDM ENGINES!!!!!!! HOW DID YOU WIRE YOUR 4 WIRE O2 SENSOR TO TAKE AWAY CEL
i have a jdm b16 in my 5th gen hatch and i have a 4 wire o2 sensor and cant get it wired right to take away my cel and run an a/f gauge?/?????? can any one tell me how to wire it ????????? thanxz
Old Apr 26, 2004 | 02:27 PM
Luserkid's Avatar
Default Re: CALLING ALL JDM ENGINES!!!!!!! HOW DID YOU WIRE YOUR 4 WIRE O2 SENSOR TO TAKE AWAY CEL (JusT a C
i have a EJ and my wire is 4 wire 02 sensor. I just plugged it in and then for the a/f gauge i tapped the white wire.
Old Apr 26, 2004 | 06:43 PM
JusT a Cx's Avatar
tapped white wire where ?
Old Apr 26, 2004 | 06:46 PM
TeamCracka's Avatar
Same here, I have a 93 and it has a 4-wire heated O2 sensor.
For the A/F gauge, you tap the white wire comming off the O2. It has two grounds (both black), a positive (red?) and a signal wire going to the ECU (white).
oldskooljdm
Mar 26, 2005 10:01 PM
93IntegraRacer
Feb 9, 2004 06:49 PM
wickedxboi
Mar 22, 2003 01:51 PM
fastcrxs1
May 23, 2002 04:11 PM
