Why do i keep blowing my ..interior lights ..break light fuse ?????
Old Oct 31, 2001 | 07:32 PM
FUP23's Avatar
New User
Default Why do i keep blowing my ..interior lights ..break light fuse ?????
Any one know ?
Old Oct 31, 2001 | 08:01 PM
AfEn808's Avatar
New User
Default Re: Why do i keep blowing my ..interior lights ..break light fuse ????? (Devin17)
does it happen when you press your brakes if so there could be a short in one of your wires.
Old Oct 31, 2001 | 08:04 PM
FUP23's Avatar
New User
Default Re: Why do i keep blowing my ..interior lights ..break light fuse ????? (AfEn808)
Sometimes...it hasnt done it in awhile..one ngiht it did it 4 times in a damn row.
Old Nov 1, 2001 | 06:50 AM
CRXtacy's Avatar
Devin, your fuses are popin cause there is too much current passing across them, more than the circut was designed to handle. Most times the cause of this is a shorted out wire (a wire that has had it's casing worn through and is now touching a metal, grounded, part of the car). If this is the scenario the most likely place to start lookin is in the "trunk" of your ride. You already know what circut the problem is on so (I would) trace the wire harness from the tail lights back towards the fuse box. I'll bet you a bong rip that something in the truck (IE: sub-woofer, car jack...ect) is rubbin against the wires when you take like a 2+G horror turn and thats why it does it intermitantly.
The other thing that could cause a circut overload is if someone tapped into the circut to power something (driving lights, poweramp...ect) and now the circut gets too hot, but only if the added load is there while the brake lights/dome light are in use.
I know intermitant probs can suck, hope this helps.
Old Nov 1, 2001 | 10:33 AM
Hondasaurs's Avatar
Do you have any aftermarket things installed such as alarm, head unit, or amps? If so who installed it? THis could be the root of your problems.
Old Nov 1, 2001 | 11:58 AM
FUP23's Avatar
New User
Default Re: Why do i keep blowing my ..interior lights ..break light fuse ????? (ZC_CRX)
Hey yes i do have a boost gauge ..a/f gauge hooked up to the fuse box....i have them ran to the single metal peices above all the fuses...is that causing it ?
Old Nov 1, 2001 | 12:34 PM
Hondasaurs's Avatar
Yea you are probably drawing too much current. Dont switch to a larger fuse either. This could start a fire! What is the make and model of your car? I can get tech sheets from DEI. You sould probably hook it to you accessory wire. Let me know and I'll give you some wireing help to get it done right.
Old Nov 1, 2001 | 12:50 PM
FUP23's Avatar
New User
88 crx si......i have the wires ran to the single metal peice above teh fuses..you know what im talking about right ??? Thanks man
Old Nov 1, 2001 | 01:51 PM
Doodoo's Avatar
I kept blowing my turn signal and hazard fuse. Come to find out it was the bulbs I used in my corners. Been working fine since I put the right ones in. Check.
Old Nov 1, 2001 | 03:44 PM
Hondasaurs's Avatar
here is you wire color codes:
YEAR: 1988 MAKE: Honda MODEL: CRX STYLE:
| ITEM | WIRE COLOR |POL | WIRE LOCATION |
| 12V |white/black | + | ign harness, f/b plug |
| STARTER |black/white | + | ign harness, f/b plug |
| IGNITION |black/yellow | + | ign harness, f/b plug |
| SECOND IGNITION
| ACCESSORY |yellow | + | ign harness, f/b plug |
| SECOND ACCESSORY |blue/white | + |ign harness, f/b plug |
| POWER UNLOCK | | | |
| PARKING LIGHTS + |red/green | |switch harness, f/box |
| PARKING LIGHTS - | | | |
| HEADLIGHTS |red/blue *3 | + |sw harness, f/b plug |
| DOOR TRIGGER |green/red | - |either running brd *2 |
| TRUNK/HATCH PIN |green/black | - |at light or indctr *2 |
| HOOD PIN | | | |
| TACHOMETER |blue | |2-pin at dist, tach *1 |
| BRAKE WIRE |green/white | + |brake pedal switch |
| HORN TRIGGER |blue/red *4 | - |steering column |
| WIPERS | | | |
NOTES:
*1 Pin A11 behind gauges
*2 Harness running down and forward from dash indicator has door and hatch
triggers.
*3 Low beam only. High-current (+)
*4 High-current ground. Use a relay when interfacing with this circuit.
Its kinda jumbuled together but i tried to clean it up. Most of these wires are located under the steering wheel. You will probably want to hook them into the YELLOW ACCESSORY. Just make sure your wires a neat and cleanly tucked away. Also you might want to consider putting an in line fuse (fusable link) to the 12V power supply of each component installed for extra safety.
Old Nov 1, 2001 | 07:54 PM
CRXtacy's Avatar
Chris thats great! What's your source? Can I get one for my car? ??
I ordered a helm manual, but they said it would take like 3 weeks to get here
Old Nov 2, 2001 | 03:35 AM
FUP23's Avatar
New User
THANKS!!! Greatly appreacited man. Any help on putting a gat *** buddy club front bumper on a rex ? lol
twiztid00002
Nov 10, 2008 07:42 AM
4DooRGiSzer
Mar 31, 2005 06:44 PM
cvcrcer
Mar 31, 2005 06:04 PM
neoburi
13
May 24, 2003 10:44 PM
