jdm 88-91 hb headlights
what modification do i have to do specifically if i was to put in the JDM 88-91 Sir headlights with the corner lights? i want to know what mods i have to do before i get it.. also there is a 1 piece for 4dr 88-91 civic that is JDM as well.. i rather have the one piece.. but anyone know what type of mods i have to do in as cuttin ... cuz i want to see if i can do it myself..thanks
_______
_______
for the JDM SiR head lights you are going to need the SiR front bumper and JDM SiR hood to match up with the head lights. The JDM head lights are a little longer then the US ones so they will not fit with the US front bumper or hood. The JDM corners should fit just fine on your car and im not too sure but i think the JDM one-peice headlights are for the 4-doors. Im sure you could do some modifactions to fit them but they alos are a little longer then the US headlihgts that are on the HB.
Hopes this helps out and sorry i dont ahve any pics to show you the differences.
ic... cuz i have a WW front kit on.. .. that would probably mean i have to get the fenders and hood.. .. man. thats 5bills
forget it
forget it
make sure you know which jdm civic you're getting your lights from. the zc civics have the same length headlight so they will fit on your usdm car with your usdm hood. the SiR civic front end has a longer, skinny headlight, and those can not be used with your usdm hood (use the sir hood). the jdm one-bulb corners should fit onto the usdm fenders. you can use your usdm corners with the jdm front (zc or sir) and it'll be ok. as far as putting on the lights, you'll need the front radiator support so that you can mount the sir headlights. again, with the zc headlights, you don't need anything else other than the headlights...
in other words if you wanna use your ww bodykit, buy the zc headlights. if you wanna go jdm then buy the whole front clip (or what you can) of an sir. i'm doing this conversion sometime in january when i have the funds for a paint job...
DOHC_C-REX
Jun 20, 2005 03:26 PM
LSBeast
Feb 27, 2003 02:25 PM
SiREXRUN
11
Nov 14, 2001 09:06 PM
