Accord Wheel Hub?
Old Apr 26, 2004 | 06:30 AM
AznJammyJam's Avatar
Default Accord Wheel Hub?
One of the lugs broke off on the front right wheel on my 94 accord LX, so im actually running on 3 lugs
i want to get it replaced, but im pretty cheap.
I saw it on The Accord Store for 135$...i want to go MUCH cheaper.
so i was thinking to check out some local junk yards, but i know for a fact there isn't many 5th gen accords lying around.
I was wondering if a 4th gen accord or lower wheel hub work out? I believe that the hub mounts on the disk brakes, and i need the correct size.
has anyone did this before? I got a haynes manual and all, but maybe some tips from you guys would do much better.
theres my first post
Old Apr 26, 2004 | 06:47 AM
RUBZERK's Avatar
Default Re: Accord Wheel Hub? (AznJammyJam)
If you go to the local honda dealer parts department, you can pick one up for $3.00
Find a local garage & the will replace it for around $30.00
Old Apr 26, 2004 | 06:58 AM
woops! i think i used the wrong word, the bolt that hold the lug broke off....=P so theres only 3 bolts to hold the wheel. heh
Old Apr 26, 2004 | 07:08 AM
spankey167's Avatar
All you need to buy is ONE wheel stud. Should cost you no more than 5 bucks. Then either DIY or find a place.
Hondafan1986
May 19, 2017 11:33 PM
soph020403@yaho
Apr 6, 2016 02:56 AM
Loco-B
Feb 28, 2007 05:20 PM
sandiegan
Oct 9, 2004 03:51 PM
GimpyAccord
Jul 23, 2003 12:36 PM
