random Code 3 Mini me Help Pleazeeeeeeee!!!!!!!
Old Apr 26, 2004 | 01:25 AM
Frederz's Avatar
Default random Code 3 Mini me Help Pleazeeeeeeee!!!!!!!
Hello,
I have tried before to get this issue resolved but no luck....
i have a mini me setup and sometimes when i drive after a while the car will start running like **** and i ll get a code 3, now what is the problem???????
please help.... bad Map sensor maybe????
if i pull over and restart the car it will run fine, till the code comes on probably about 6 hours later
i have pictures of the wiring if need it
please help
Thank You
Old Apr 26, 2004 | 12:45 PM
Frederz's Avatar
Default Re: random Code 3 Mini me Help Pleazeeeeeeee!!!!!!! (Frederz)
i come no one can answer me ?????????
Old Apr 26, 2004 | 12:53 PM
crx_88_si's Avatar
what car? what ecu? what motor parts?
Old Apr 26, 2004 | 02:38 PM
Frederz's Avatar
Default Re: random Code 3 Mini me Help Pleazeeeeeeee!!!!!!! (crx_88_si)
1990 CRX si with mini me swap and z6 intake manifold
Old Apr 26, 2004 | 02:43 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frederz &raquo;</TD></TR><TR><TD CLASS="quote">1990 CRX si with mini me swap and z6 intake manifold</TD></TR></TABLE>
wich MAP u using??
the one on the stock firewall ???
or the one on the Z6 intake manifold???
unplug the stock one and plug it to the one on the Z6 manifold..
if so then u got a bad MAP
if not then u dont have the MAP hooked
Old Apr 26, 2004 | 09:52 PM
Frederz's Avatar
Default Re: random Code 3 Mini me Help Pleazeeeeeeee!!!!!!! (USDM 4G VTEC)
the map plug is plugged in the map sennsor on top of the T. body i am not sure what the problem is because it does it randomly..... any other ideas????
cougar289
Apr 11, 2009 07:48 AM
EJAYATE
12
Feb 8, 2008 11:01 AM
PYITR821
May 25, 2006 09:16 PM
saccord
Dec 13, 2005 12:50 AM
HatchBox
Sep 28, 2003 07:22 PM
