prelude motor in accord with no spark
Old Apr 25, 2004 | 05:54 PM
Big Black's Avatar
Default prelude motor in accord with no spark
Hey i just put a 97 H22 motor in my 96 accord and do not have spark. I replaced the coil and still don't have it. Does anyone know why?
Old Apr 25, 2004 | 06:44 PM
cyberneo344ib's Avatar
Default Re: prelude motor in accord with no spark (Big Black)
did you check all the grounds?
Old Apr 26, 2004 | 05:38 AM
Big Black's Avatar
Default Re: prelude motor in accord with no spark (cyberneo344ib)
i checked all the grounds. but I'll check then again. I'll do almost anything at this time...
Old Apr 26, 2004 | 10:14 AM
P!cKl3$'s Avatar
Did you check the ground on the Thermostat housing? That one is often forgotten so I'm just trying to narrow it down. You might also want to check your compression and timing. Good luck man.
Old Apr 26, 2004 | 12:41 PM
Big Black's Avatar
Default Re: prelude motor in accord with no spark (P!cKl3$)
do accord and prelude have a ground on the thermostat housing??? i don't rember seeing one.
Old Apr 26, 2004 | 03:15 PM
accordingly's Avatar
i read in another forum to check the ecm fuse under the hood, when that goes then you will get no spark or gas to motor
Old Apr 27, 2004 | 11:38 AM
dblack's Avatar
Default Re: (accordingly)
I do not see a ground strap on my thermostat
housing.. I am having a similar problem on my
93 accord..
dima
Aug 30, 2006 02:00 PM
Big Black
May 3, 2004 05:24 PM
ThightAccord
Apr 16, 2002 11:35 AM
