After turbo car wont rev past 7200.
Old Apr 25, 2004 | 05:27 PM
Yellb16crxsi's Avatar
Default After turbo car wont rev past 7200.
after my turbo install i noticed that my b16 would no longer rev past 7200(numbers via safc). what could be the casue of this?
Old Apr 25, 2004 | 05:33 PM
b16ahybrid's Avatar
Default Re: After turbo car wont rev past 7200. (Yellb16crxsi)
Anything.
whats your set-up?
It's kinda hard to diagnose a problem with not history.......you should know this considering your post count.....list your set-up
Old Apr 25, 2004 | 05:54 PM
Default Re: After turbo car wont rev past 7200. (b16ahybrid)
lol, sorry just got back from nopi and i am very tired and dissapointed in my car...
the setup is a b16 with a tdo5 with the stock wastegate(8lbs). it is running the hack. stock ignition. non-chipped pr3 ecu.
the car will go into vtec and pull hard untill right around 7.2k then it just seems like you hit a brick wall. the ecu isnt throwing any codes.
and it only seems to start doing this about a week after the turbo was intalled.
Old Apr 25, 2004 | 05:59 PM
b16ahybrid's Avatar
Well without knowing anything else I'm going to venture out and say that it sounds like your running to rich. Usually the problem that you descridbed is due to air fuel rtio problems.
Have you had it on a dyno yet?
Old Apr 25, 2004 | 06:02 PM
no dyno yet...c ould the proble be from bad o2 sensor placement.... cause the down pipe that we made we used the stock mitsu o2 housing and put 1 o2 sensor there and put the othe one alittle further down the downpipe.
also there was a problem with it not wanting to hold at a certain rev when i was launching... it would go up then back down like 500 rpms then back up again.
Old Apr 25, 2004 | 06:05 PM
b16ahybrid's Avatar
Nah doubt it....
Does it rev fine then suddenly stop like it's hit a wall?
Old Apr 25, 2004 | 06:24 PM
Mag00n's Avatar
What are the specs on your turbo? Your turbo could just be running out of breath on the high revving b16. Like the other guy said.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">Nah doubt it....
Does it rev fine then suddenly stop like it's hit a wall?</TD></TR></TABLE>
Or does it just slow down?
Old Apr 25, 2004 | 06:43 PM
Default Re: After turbo car wont rev past 7200. (SICKSOLVTEC-T)
yeah revs fine until 7.2k and its not the turbo running outta breath. one race my charge pipe popped of and i still went up to see if it would go past 7.2 and nope hit 7.2 and just wouldent rev any higher!
Old Apr 25, 2004 | 06:46 PM
b16ahybrid's Avatar
Sounds like your running to rich. I had that same problem and fixed it when I realized my air/fuel ratio was 10.0:1 + under boost. leaned it out to about 11.5 and solved the problem
Old Apr 25, 2004 | 06:56 PM
would running rich really do that... i had no idea.. i will get the numbers i have the safc set to tommarow.
Old Apr 26, 2004 | 05:05 AM
bump any other ideas?
Old Apr 26, 2004 | 06:52 AM
kyle h.'s Avatar
running lean does that too. what for injectors and fuel pump do you have?
my talon does the same thing, but at 6200 rpm. while monitoring the fuel injectors they go from ~24ms (injector pulse width) to ~1.6ns. the problem lies behind the fuel pump. it's stock and needs to be rewired, for more voltage at the pump...might help the problem a bit. but really, i need to get an aftermarket pump, like a 190 or something.
so whats your fuel setup?
Old Apr 26, 2004 | 07:20 AM
Default Re: After turbo car wont rev past 7200. (kyle h.)
i have dsm 450 injectors with stock crx si fuel pump.
Old Apr 26, 2004 | 07:22 AM
now it does this if it is boosting or not. it did this even when the i had the charge pipe pop off.
Old Apr 26, 2004 | 07:31 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. &raquo;</TD></TR><TR><TD CLASS="quote">running lean does that too. </TD></TR></TABLE>
If he was running lean power would just taper off, It would still rev like it's running fine (unless it's extreemly lean)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellb16crxsi &raquo;</TD></TR><TR><TD CLASS="quote">now it does this if it is boosting or not. it did this even when the i had the charge pipe pop off.</TD></TR></TABLE>
Too much fuel at that rpm point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellb16crxsi &raquo;</TD></TR><TR><TD CLASS="quote">would running rich really do that... i had no idea.. i will get the numbers i have the safc set to tommarow.</TD></TR></TABLE>
Yep......
Old Apr 26, 2004 | 07:48 AM
tegmech's Avatar
MAKE sure its not running lean though. I know that it can get too rich and start to break up, but that is like at 8:1 from my experience. And when you lean out too much, it definetly can be like hitting a brick wall.
hehe, as a matter of fact, last night when me and a buddy's math were off somehow while tuning fuel maps, it felt like we slammed into one. But the a/f ratio shot through the roof. Upwards of 25 in some parts.
Remember kids, don't drink and tune.
and no...i was not the one driving
Old Apr 26, 2004 | 08:15 AM
DXK Eg's Avatar
Default Re: (tegmech)
check your oil that happen to me too and i was low on oil.But i couldn't go past 4500 rpm when vtec kicks in..
Old Apr 26, 2004 | 10:19 AM
Default Re: (dynasty-x-motorsport)
1k=-40%
2k=-37%
3k=-34%
4k=-32%
5k=-30%
6k=-30%
7k=-30%
8k=-29%
with dsm 450's @ 8 lbs
Old Apr 26, 2004 | 07:57 PM
Default Re: (Yellb16crxsi)
i put all numbers across the board to -40% since there is no boost there due to my wastegate actuator is broken and it just opens whenever the engine is reved.
and it still stops at 7.2k......
Old Apr 27, 2004 | 06:02 AM
bump please help me
Old Apr 27, 2004 | 01:40 PM
up
Old Apr 27, 2004 | 01:43 PM
Teg4e's Avatar
i don't know ECU code names, but is that ECU from an LS or another car that has a fuel-cut at 7200? My LS integra cuts off at 7200. maybe just a coincidence.
Old Apr 27, 2004 | 02:45 PM
Mag00n's Avatar
Default Re: After turbo car wont rev past 7200. (Teg4e)
Nope, that ECU is an OBD-0 b16 ecu.
Old Apr 27, 2004 | 04:18 PM
dunkd's Avatar
do u have an FMU?
Old Apr 27, 2004 | 07:35 PM
Default Re: (dunkd)
nope i am running the hack........ ... like i said i turned it back to all -40% since i am not boosting anymore so they act like 240cc injectors.. and it still does that.
