600 F4i Blinker Replacement. Anyone that has ever removed their front fairing.
I took it off today and came to realize that the blinkers I had got from a friend only hadto wires on them. The F4i has the two wires needed but it then has a green wire by itself. Because I was lacking the third wire I could not install the new set of blinkers. Do I have to find blinkers with this third wire or is their another way to rig it?
If I remember correctly, you don't need to have all three wires hooked up. Without the third wire installed, your blinkers will turn on only when they are activated. With the third wire installed, you'll have running lights which will blink when you signal.
That's right, if you want to have running lights you'll need to get flush mounts that are equipped with them, specifically the carbon fiber clear ones then you can have white running lights and yellow blinkers.
jdmej814
Lighting
Jan 30, 2008 02:07 PM
