D15B VTEC engine swap
Old Apr 25, 2004 | 04:07 PM
SunkistRex's Avatar
Default D15B VTEC engine swap
Will a DX tranny hook up to this, what all do i need.. it comes with
YOUR SWAP INCLUDES
»Motor
»Distributor
»Complete Intake Manifold
»Alternator
»A/C Power Steering Pump
»All Brackets and Sensors
Do i need a wiring harness.. or can i use my SI harness.. thanks in advance
Old Apr 25, 2004 | 05:59 PM
BlueCrxNC's Avatar
Your DX tranny will work fine.
You should also be fine in using your Si harness... you just need to add in the wiring for VTEC switch and VTEC Pressure Switch, and relocate/extend the wires from your current Map Sensor (located on firewall) to the Intake manifold on the new motor... that is of course if you decide to use the D15B's intake mani.
Old Apr 25, 2004 | 07:10 PM
SunkistRex's Avatar
Default Re: (BlueCrxNC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">Your DX tranny will work fine.
You should also be fine in using your Si harness... you just need to add in the wiring for VTEC switch and VTEC Pressure Switch, and relocate/extend the wires from your current Map Sensor (located on firewall) to the Intake manifold on the new motor... that is of course if you decide to use the D15B's intake mani.</TD></TR></TABLE>
cool, its only 400 so i might get it since i need a new motor...
Old Apr 25, 2004 | 07:14 PM
SunkistRex's Avatar
Default Re: (SunkistRex)
also will my eccu *si* work ?
Old Apr 25, 2004 | 07:16 PM
EG8R's Avatar
It will work but you will need a switch to activate VTEC.
Or convert to OBD1.
Old Apr 25, 2004 | 07:17 PM
SunkistRex's Avatar
Default Re: (skelly ed666)
what kind of switch? im thinkin u mean toggle..
Old Apr 25, 2004 | 08:14 PM
kranked91dx's Avatar
don't do the switch thing, it dosn't work's really well since you didn't advance timming under Vtec and losing a few pony right there.
convert to OBD1 with a blownhatch90 harness ( easy as 1,2,3 )
use a PO8 ecu with the RPT program, the P28 will now work perfectly with your application cause of the 2 o2 sensor, the D15b use only 1, 1 wire O2 sensor
thath's about it,
Kranked
MGBej1503
May 6, 2012 11:00 AM
03EM2guy
Apr 19, 2011 01:17 PM
eg_junior
Jan 16, 2007 06:24 PM
