b16a timing?
Old Apr 25, 2004 | 04:04 PM
enhancedCL9's Avatar
Default b16a timing?
when i was about to do my timing, i pointed the timing light at the crank and i only saw 1 red mark and a white mark. Which should i set it at for the stock specs? And shouldn't there be more then just two marks for a 90 Jdm b16a? Thanks.
Old Apr 25, 2004 | 05:14 PM
michael O's Avatar
Default Re: b16a timing? (SLOW CRX)
I have the same engine and there are four notches on the crank pulley. Three close together and one about an inch away. So I have on clue what's going on with your car...
Old Apr 26, 2004 | 07:55 AM
Default Re: b16a timing? (michaelOlson)
i know what your talking about, but mines looks nothing close to that. i only got two marks. Any other heLp pLease?
Old Apr 26, 2004 | 08:36 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The white mark by itself is top dead center..
That position is for adjusting valves or when
you are replacing the timing belt etc.
The red mark in the center of the two gray marks is for setting ignition timing.
Go here and download the VTEC supplement for more info:
http://www.acute.f9.co.uk/crx/...s.htm
Kaleb_Johnson
Jul 3, 2014 12:19 PM
sde780
33
Jan 7, 2011 08:37 PM
civic_driver
May 7, 2009 03:46 PM
1SloNeon
Jan 27, 2008 10:15 AM
civc_tt
Jul 25, 2006 09:03 PM
