Pick a swap for my 98 ex
Old Apr 25, 2004 | 02:18 PM
rovigian's Avatar
Default Pick a swap for my 98 ex
I need help deciding on a swap for my daily driver 1998 ex.
The car will basically be a sleeper, but it will not be raced.
Old Apr 25, 2004 | 03:35 PM
dohcturtle's Avatar
Default Re: Pick a swap for my 98 ex (rovigian)
K20a...its just money,don't be shy.
Old Apr 25, 2004 | 03:42 PM
kaptr1d's Avatar
i dont really like the options u provided, i think there are better choices.
if u just want a daily driver get a b16a2...
Old Apr 25, 2004 | 03:45 PM
91dxcrx's Avatar
Default Re: (kaptr1d)
b18
Old Apr 25, 2004 | 04:00 PM
rovigian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaptr1d &raquo;</TD></TR><TR><TD CLASS="quote">
if u just want a daily driver get a b16a2...</TD></TR></TABLE>
The transmission on that motor has syncro problems.
Old Apr 25, 2004 | 04:22 PM
Ddogz15's Avatar
Default Re: (rovigian)
h22 yuppp
Old Apr 25, 2004 | 06:33 PM
spirit R
Guest
Posts: n/a
Default Re: (Ddogz15)
I say you stick with the D series
http://www.exospeed.com has the parts to make it a 13 sec car on street tires which is really pretty damn fast for a civic daily driver without going poor on tires and suspension
Old Apr 25, 2004 | 07:54 PM
rovigian's Avatar
Default Re: (spirit R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spirit R &raquo;</TD></TR><TR><TD CLASS="quote">I say you stick with the D series
http://www.exospeed.com has the parts to make it a 13 sec car on street tires which is really pretty damn fast for a civic daily driver without going poor on tires and suspension</TD></TR></TABLE>
I want the reliabilty though, I won't have much time to work on it after the swap is done.
Old Apr 25, 2004 | 07:59 PM
spirit R
Guest
Posts: n/a
There is nothing more reliable than a d series
especailly since you will be driving on a motor you know the history of.
You can even buy a spare and have it nicely built for the street and swap it in a couple hours without the usual motor swap mess
When you buy a swap from most places it comes with a startup warranty which means all 4 bearings could be spun but as long as it turns over and rod knocks to life mission accomplished
now this does'nt happen very often but soemtimes I wonder "if you had to replace your engine or rebuild every 40K like the JDMers would you care if the oil level was low the last 10 K ?"
Old Apr 25, 2004 | 08:07 PM
rovigian's Avatar
I can't see much reliability coming out of a d series if its in the 13-14 second range. Seems easier to get the power with more displacement instead. This is just gonna be a daily driver anyways. Most people seems satisfied with thier JDM swaps it seems...
Old Apr 25, 2004 | 08:11 PM
spirit R
Guest
Posts: n/a
I drove my 11 sec hatch to work everyday for 6 mos. With another 400 #'s it would be in the 13 sec range
a big diff is in the final drive upgrade for that trans
For the price of a swap you could have this instead
All motor D16Z6 - SOHC daily driver
Street strip 11.0 comp. JG Redline series head package with 85VT80 camshaft, with modified stock ECU.
160 Hp and 119 Lbs. of torque at the wheels.
Old Apr 26, 2004 | 08:17 AM
1hotcivicSi's Avatar
if its not gunna be raced keep ur engine
Old Apr 26, 2004 | 05:00 PM
b20_ed's Avatar
Default Re: Pick a swap for my 98 ex (1hotcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">if its not gunna be raced keep ur engine </TD></TR></TABLE>
exactly!
Where the hell is the B20 option??
Old Apr 26, 2004 | 05:04 PM
spirit R
Guest
Posts: n/a
Default Re: Pick a swap for my 98 ex (b20_EK)
Lost in the "ITs NUt vTak itZ n0t PimpZoR" noise I'm afraid
Old Apr 26, 2004 | 05:19 PM
Just-Dumb's Avatar
Default Re: Pick a swap for my 98 ex (spirit R)
Why would you go out of your way to swap and just drive it 5 under the speed limit?
Old Apr 26, 2004 | 05:59 PM
spirit R
Guest
Posts: n/a
Default Re: Pick a swap for my 98 ex (Just-Dumb)
that kind of attitude gets your car snatched up quick by the po's
and once you get one ticket the rest start flowing in
Old Apr 26, 2004 | 09:13 PM
rovigian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just-Dumb &raquo;</TD></TR><TR><TD CLASS="quote">Why would you go out of your way to swap and just drive it 5 under the speed limit?</TD></TR></TABLE>
I don't im 18, I drive like a manic, I just don't street race (nothing against it though). The d16 is too slow for my liking thats all.
Old Apr 27, 2004 | 05:30 AM
VTECVillain's Avatar
I would have to say B20B/Z with GSR tranny and OBD1 conversion of course. Good low-end grunt and you don't have to rev all day to feel the power, great daily driver setup.
I think the GSR is a bit pricey for something you never plan to do anything more with than drive daily. Same applies to the H22A, not to mention the added work on to be daily driven
Old Apr 27, 2004 | 07:51 PM
hondaZvic's Avatar
Default Re: Pick a swap for my 98 ex (VTECVillain)
u say here
h22- harder swap, more torque. = TRUE
b18- easier swap, reliable long term = FALSE
the h22 is just as reliable as a b18.
alot of problems that people tend to have when swapping in an h22 come from the installers part.... or from an aftermarket part malfunction...ie: bad mounts, sorry axles. cel - due to something wired incorrectly or not at all....
now if we were to hear of something like.. water pumps going out... oil pumps going out... something actually connected to or in the engine breaking all the time.. then the h22 could be called not reliable... but we dont here these things all the time.. or at least i dont... in fact i cant remember the last time i heard about an h22 breaking down at all.... or even a b18 for that matter...
both are very good engines.
but i vote for H22. u drive like a maniac u say... this would fit u very well.
Old Apr 27, 2004 | 09:42 PM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">
I don't im 18, I drive like a manic, I just don't street race (nothing against it though). The d16 is too slow for my liking thats all.</TD></TR></TABLE>
ok.... Y did u post this twice?
Old Apr 27, 2004 | 09:45 PM
rovigian's Avatar
Must have been an error because I only typed it once.
Old Apr 27, 2004 | 09:47 PM
hondaZvic's Avatar
Default Re: Pick a swap for my 98 ex (hondaZvic)
ok.. mah bad... it must be my comp.... cuz i dont see it anymore.... either that.. or im drinking to much.....
Old Apr 28, 2004 | 06:28 AM
UrVtecIsLoud's Avatar
Default Re: Pick a swap for my 98 ex (dohcturtle)
Yes k20 will kick ***
Old Apr 28, 2004 | 01:13 PM
MPower332TI's Avatar
Default Re: Pick a swap for my 98 ex (RottenEggJDM)
H22a or a K20. H22's are nice due to the high tourqe numbers. GSR swaps are really nice also. I had both H22 and GSR swaps in my old 97 dx coupe and loved them both. The GSR is an easier swap and a bit cheaper. It ran a 9.0 1/8th mile right before i got rid of it.
chickenwing
34
Nov 15, 2008 06:17 PM
jbrokos307
15
Jul 23, 2007 09:00 AM
sosnowchik
Oct 18, 2006 12:31 PM
Mandark06
Sep 10, 2006 11:02 PM
TrunkRattlin
14
Feb 13, 2006 06:41 PM
