EG wiring question....
memoryFAB.com representative
after checking all the fuses, and the wiper motor i get no power to the wipers. front and rear! i had a mechanic look it over and he said it was in the wiring. could anyone help. im not a wiring expert at all. but i dont want to pay out the *** to have the problem fixed and driving home last night in the rain wasn't fun and rainX doesn't last that long...thanxx in advance!
your best bet is to get a dvom and get a wiring diagram. Its a pain in the **** and its time consuming, but it will save you the money. Just check what the wipers run through, check your switch. Chances are that its an open or bad conection. dont fret.
DVOM = Digital Volt Ohm Meter
get a copy of a helm then check voltages at the fuse
sometimes the switch goes bad so take it off and clean it up then check
