How to connect FITV on AEBS manifold?-Would that work?
Old Apr 25, 2004 | 02:23 AM
germanEE8's Avatar
Default How to connect FITV on AEBS manifold?-Would that work?
Hey,
I installed a AEBS manifold at my b16a1 engine. It doesn't support the FITV.
I have a idea how I could connect it. Using a y-connector at the vacuum port for the brake booster.Would that work?-Brake booster needs a vacuum and the FITV provides air. Can I connect that to one port???
Do I need the FITV?
thanks,
marc
Old Apr 25, 2004 | 03:59 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: How to connect FITV on AEBS manifold?-Would that work? (germanEE8)
Whats the FITV
Old Apr 25, 2004 | 04:34 AM
germanEE8's Avatar
Default Re: How to connect FITV on AEBS manifold?-Would that work? (Vortech99Si)
Fast Idle Thermo Valve
greets
marc
Old Apr 25, 2004 | 06:17 AM
mmuller's Avatar
Mad Scientist
no, it wouldnt work, FITV needs source of ait from before the tb and then an output t after the tb( into the manifold).
You can just leave the fitv out.the car will just idle lower when its cold, no biggie
Old Apr 25, 2004 | 06:29 AM
germanEE8's Avatar
Default Re: How to connect FITV on AEBS manifold?-Would that work? (mmuller)
Of course I would place an additional hose from the intake pipe to the fitv. Then a hose from the fitv to a y-connector as shown in the picture...
Or?
greetz
marc
Old Apr 25, 2004 | 06:32 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by germanEE8 &raquo;</TD></TR><TR><TD CLASS="quote">Of course I would place an additional hose from the intake pipe to the fitv. Then a hose from the fitv to a y-connector as shown in the picture...
Or?
greetz
marc</TD></TR></TABLE>
i guess if you reaallly wanted to have it then....
you would have to make a adapter plate for the fitv to connect the hoses that you say....
or...
leave it out
Old Apr 25, 2004 | 06:55 AM
germanEE8's Avatar
Hm, leave it out would be the easiest way of course.
But what about starting the engine on colder days?
Doesn't the fitv affect my idle?
thanks,
marc
Old Apr 25, 2004 | 07:15 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by germanEE8 &raquo;</TD></TR><TR><TD CLASS="quote">Hm, leave it out would be the easiest way of course.
thanks,
yes, as sayd, it will idle lower when car its cold, for ex: instead of 2000 rpms, it will idle at 1000 when cold
Old Apr 25, 2004 | 07:42 AM
germanEE8's Avatar
Does it stay at 1000revs or does it drop till the engine shuts down ?
thanks,
marc
Old Apr 25, 2004 | 09:48 AM
cleanaccord1997's Avatar
technicaly you could leave the FITV out but starting the car in a colder climate will require some finesse but it would be do able if u live in a warmer climate then by all means go ahead
Old Apr 25, 2004 | 11:55 AM
germanEE8's Avatar
Default Re: How to connect FITV on AEBS manifold?-Would that work? (cleanaccord1997)
Well, I live in germany, but only drive my car in the summer, so I think I'll leave it off for now. If I run into trouble I can still install it.
Big thanks!
Marc
chickenwing
Sep 24, 2008 09:48 PM
duyfash0
Jun 2, 2007 02:30 PM
iphatcrxi
Nov 14, 2006 03:04 PM
E-spec Tuner
Jun 10, 2005 11:46 PM
tkHBseries
Feb 18, 2004 06:21 AM
