recommended octane for JDM D16Z6
Old Apr 24, 2004 | 11:04 PM
suspendedHatch's Avatar
Default recommended octane for JDM D16Z6
Whats the recommended octane for a JDM D16Z6? Please specify whether its RON or the US rating.
Old Apr 25, 2004 | 03:13 PM
func-tion's Avatar
Default Re: recommended octane for JDM D16Z6 (shaundrake)
Is there a such this a JDM d16z6?
Anyways I run the lowest octane (?87?) arco has to offer. As long as your motors stock you should have little to worry about. If you have i/h/e maby bump it up to the middle grade octane if you spark plugs start to get white.
Old Apr 25, 2004 | 03:49 PM
Default Re: recommended octane for JDM D16Z6 (func-tion)
IHE doesn't change your compression or ignition timing, so why would you run higher octane for that? If those mods cause you to run lean you will want to raise your fuel pressure. Thanks for responding though.
Anyone else? I was hoping to find the actual factory recommended octane. Rather than put in some 87, buy some bottles of octane booster just in case, and cross my fingers.
Old Apr 25, 2004 | 03:59 PM
Jimmy's Avatar
Global Moderator
Um.. The reccomended octane is unleaded.
87,89 or 93 will work...
If you have your timing advanced then you need higher octane.
Search.
Old Apr 26, 2004 | 01:58 AM
Default Re: (Usdmdc2)
I did search, thank you.
daredeezy619
21
Dec 17, 2008 05:12 AM
redcoats1976
43
Jul 11, 2008 08:06 PM
dstrout
Aug 23, 2006 01:15 PM
hondapwr
Jul 5, 2006 05:22 AM
Lysawy
Dec 26, 2002 01:03 AM
