ecu code 67. how to fix?
Old Apr 24, 2004 | 10:38 PM
ILOVEGIRLS's Avatar
Default ecu code 67. how to fix?
67 Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
does this mean i need a new cat?
Old Apr 25, 2004 | 03:11 PM
taz77's Avatar
New User
Default Re: ecu code 67. how to fix? (ILOVEGIRLS)
yup, you're cat is starting to go out... it may not be totally dead yet, but if you're expecting on doing a smog test anytime soon, you might want to look into prices for a new one...
Old Apr 26, 2004 | 02:28 PM
ILOVEGIRLS's Avatar
Default Re: ecu code 67. how to fix? (taz77)
isnt there a bypass thing you can do to make the light go away?
Old Apr 26, 2004 | 02:50 PM
taz77's Avatar
New User
well... let me ask you a few things before i make any suggestions
are you planning on doing a smog check anytime soon?
are you planning on selling your car?
is the car for commuting, cruising, city driving?
Old Apr 26, 2004 | 08:40 PM
ILOVEGIRLS's Avatar
the car is just daily driving. no racing, no smog anytime soon and not planning to sell the car anytime soon.
Old Apr 27, 2004 | 06:16 PM
taz77's Avatar
New User
just reset the ecu and hope it doesn't come on again... that's really the only thing you can do right now...
Old Apr 28, 2004 | 08:51 PM
ILOVEGIRLS's Avatar
shucks.
i reset it a bunch of time already. how do obd 2 guys run a gutted cat without the check engine?
Old Apr 28, 2004 | 09:43 PM
C_Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILOVEGIRLS &raquo;</TD></TR><TR><TD CLASS="quote">shucks.
i reset it a bunch of time already. how do obd 2 guys run a gutted cat without the check engine?</TD></TR></TABLE>
Simple! Just buy an ECU simulator for about $30 bucks and that <U>should</U> stop the CEL from coming on.
Old Apr 28, 2004 | 10:26 PM
h2392si's Avatar
Default Re: ecu code 67. how to fix? (C_Civic)
i have the same problem, where can i get an o2 simulator that works and who knows how to put one one? thanks in advance.
Old Apr 28, 2004 | 10:30 PM
taz77's Avatar
New User
is that an ecu simulator or an o2 simulator? a p0420 code is set when the secondary o2 sensor shows an oscillating voltage similar to the primary o2... it should be fairly steady.
you might be able to "fool" the ecu into thinking the cat is working right IF you're able to provide the ecu a constant 0.6v
Old Apr 28, 2004 | 10:51 PM
C_Civic's Avatar
its a small chip that u put on your Ecu to trick it to believing that the secondary O2 sensor is even there....or its running fine...I've heard it works and i just ordered mine and will give it a try this weekend....check Ebay for it....i forgot the other web page!
Old May 1, 2004 | 11:31 AM
H22A EG6's Avatar
we just put the O2 sim on and it works great
Old May 2, 2004 | 07:47 PM
C_Civic's Avatar
Default Re: ecu code 67. how to fix? (H22A EG6)
O2 simulator works great....ever since the install...the CEL light hasnt come on.
sinfulDB1
May 26, 2010 10:27 AM
Try2Live4God
Oct 3, 2007 05:26 AM
onyx00
Jan 8, 2006 02:47 PM
tegrunner
Aug 22, 2003 02:09 AM
shatshadarach
Acura TL, RL & ZDX
Jul 22, 2003 05:08 PM
