Routing door lock and unlock wires for alarms
Old Apr 24, 2004 | 09:49 PM
MestizoRacer310's Avatar
Default Routing door lock and unlock wires for alarms
I have the wires routed between the door panel and the door itself...and I tried running it through the OEM loom. Any suggestions on getting it cleaned up?? I'll try to get pics of it ASAP so you know what I'm talking about. I hope I'm not confusing anyone......
Old Apr 24, 2004 | 10:48 PM
Xsi's Avatar
Xsi
I ran mine through the oem loom, I tried to use a drill but it didn't fit so I melted a hole with an old soldering iron.
Old Apr 25, 2004 | 06:23 AM
rjr162's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">I ran mine through the oem loom, I tried to use a drill but it didn't fit so I melted a hole with an old soldering iron.</TD></TR></TABLE>
lol same thing I had to do when I installed the DEI window automation system for a customer.
Old Apr 25, 2004 | 02:21 PM
Default Re: Routing door lock and unlock wires for alarms (MestizoRacer310)
The green's for the door unlock (the lock function is fried in the alarm brain) and the red and black are connected to the battery.
Old Apr 25, 2004 | 02:33 PM
audioroach's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">I have the wires routed between the door panel and the door itself...and I tried running it through the OEM loom. Any suggestions on getting it cleaned up?? I'll try to get pics of it ASAP so you know what I'm talking about. I hope I'm not confusing anyone......</TD></TR></TABLE>
On hondas at least the early ones without a molex plug
the best way to do it is to remove the doors
run your wires ( basically make your own harness )
wrap it in tape.. use 3M 33+ vinyl tape
remember to run all wires as well a future plan
( that way you do it once)
replace door
thats it.
happy installing
that it
Old Apr 25, 2004 | 02:38 PM
audioroach's Avatar
The green's for the door unlock (the lock function is fried in the alarm brain) and the red and black are connected to the battery.</TD></TR></TABLE>
Okay this is some really scary ****...but at least your asking for help.
Old Apr 25, 2004 | 04:53 PM
Xsi's Avatar
Xsi
If you can't work out anything else just drill another hole but please don't leave it like that!
At least tape the wires up, you can never have enough black insulation tape.
Old Apr 25, 2004 | 06:51 PM
audioroach's Avatar
Default Re: (Xsi)
I looked at the pic again..
He has a loom running into the door already
all his has to do is.
a. remove lockpin on door.
b. unbolt door from car.
c. route wires through loom.
d. reattach door.
Old Apr 25, 2004 | 09:15 PM
Default Re: (audioroach)
So there's NO WAY I can do this without removing the door?
On a side note:
I want to install additional LEDs on each door...with that said...how do I get full power to each LED using the ONE output off the alarm brain???
Old Apr 25, 2004 | 10:01 PM
Xsi's Avatar
Xsi
I didn't remove the door, I knocked that pin out to make it open further then I unplugged the plug, burned through it, plugged it back in and ran the wire through.
Old Apr 26, 2004 | 08:28 AM
john666's Avatar
heres the ghetto way i did it.
Old Apr 26, 2004 | 11:29 PM
LSP's Avatar
LSP
instead of taking off the door, why dont you just take off the fender..its much easier to work with and not as heavy. Take off the fender, then route your wire. Any like someone else said.. while you are at it, route a few extra ones for future mods. As for the LED. just wire them positive to positive, negative to negative.
Old Apr 27, 2004 | 03:42 PM
Default Re: Routing door lock and unlock wires for alarms (audioroach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audioroach &raquo;</TD></TR><TR><TD CLASS="quote">On hondas at least the early ones without a molex plug</TD></TR></TABLE>
Unfortunately, I had the displeasure of finding out that it is a molex plug. So I guess I'll just have to drill a new hole. With that decision already made, should I use the split loom or just wrap it generously with electrical tape??
Old Apr 28, 2004 | 08:36 PM
philly-O's Avatar
on older cars such as my ef, run wires through the boots but outside the factory loom, but wrap the whole thing in tape for the factory look. newer cars with the molex plugs, i run the wires through the boot but outside of the plug (still inside the boot). using a unibit on my right angle drill, i oval the opening just enough to fit the new wires keeping the boot tight enough to seal back up. i definately charge extra for this service at work. goodluck
Old Apr 29, 2004 | 12:59 PM
foz's Avatar
foz
time to go get professional installtion....
no wires should travel from under the hood and through the fender!!!!!!
the lock wires are scary, and a better way is found, but those wires coming from under the hood are just wrong!
Old Apr 29, 2004 | 07:26 PM
Default Re: Routing door lock and unlock wires for alarms (foz)
There's an oval plug under, what I'm guessing is the fuel filter. I'll try to feed the battery wires through there.
Old Apr 30, 2004 | 08:51 PM
brads94accord's Avatar
i did mine kinda the ghetto way and ran it between the door panel and door, then into the car through the grommet in the door sill. but i covered mine in some black wire loom. the stuff i got with my amp wiring kit.
saveacivic
Audio / Security / Video
21
Jan 24, 2007 07:18 PM
p nut
Jun 26, 2005 05:49 PM
Maverik4k
Sep 22, 2004 09:56 PM
binkster
Oct 30, 2003 10:16 PM
tsjeff
Aug 9, 2003 10:42 AM
