Aluminum flywheel replacement friction surface
Old Apr 24, 2004 | 08:47 PM
MintFlavored's Avatar
Default Aluminum flywheel replacement friction surface
I have a CM aluminum flywheel, and I was wondering where I could get a new steel friction surface for it.
The flywheel I have is 7.5 lbs, and has a full 360 degree, one piece, bolted ring.
Old Apr 25, 2004 | 08:09 AM
Default Re: Aluminum flywheel replacement friction surface (MintFlavored)
bumpy
Old Apr 25, 2004 | 08:25 AM
Padawan's Avatar
Darth ModerVader
Any place that sells the flywheel should be able to supply you with the friction surface. Have you contacted the place where you bought the flywheel?
Old Apr 27, 2004 | 05:18 PM
slooogsr's Avatar
id also like to know........ i wish i knew the life expectancy of these surfaces. mine has had plenty of time being flogged by a ceramic clutch disc.........
Old Apr 27, 2004 | 06:08 PM
Tweakmeister's Avatar
call clutchmasters
immalooser
Oct 18, 2005 08:08 PM
b16a27
Nov 5, 2004 04:43 PM
NightHawkC5
Mar 18, 2003 11:31 AM
