B16A2, What do they come in?
Old Apr 24, 2004 | 08:46 PM
eL's Avatar
eL
Default B16A2, What do they come in?
Does the B16A2 only come in the Si coupe or does it come in other honda models? I'm confused
Do they also come in the DOHC Delsol?
Old Apr 24, 2004 | 08:53 PM
turbo'd's Avatar
Default Re: B16A2, What do they come in? (eL)
they came in jdm 92-95 civics SIRs and in 93-95 del sols.
Old Apr 24, 2004 | 08:56 PM
skip.two's Avatar
Default Re: B16A2, What do they come in? (turbo'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo'd &raquo;</TD></TR><TR><TD CLASS="quote">they came in jdm 92-95 civics SIRs and in 93-95 del sols. </TD></TR></TABLE>
wrong.
B16A2's came in 99-00 Civic Si's and 96-97 Del Sol VTEC's.
94-95 Del Sol VTEC's came with B16A3's.
Old Apr 24, 2004 | 09:01 PM
eL's Avatar
eL
Default Re: B16A2, What do they come in? (jL iLLuZiOnz 9)
Hmm, I have a B16A2 and I believe I'm using an 0BD1 ecu, I dont remember exactly which one it is but i'll look tomorrow. It's NOT the A2's ECU though. So I would need to know where the B16A2 I have came from in order to get the right ECU i'm guessing.
Old Apr 24, 2004 | 09:02 PM
turbo'd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">
wrong.
94-95 Del Sol VTEC's came with B16A3's.</TD></TR></TABLE>notice how i said jdm, i am not wrong, i just only gave the jdm answer and not the usdm one .
Old Apr 24, 2004 | 09:10 PM
skip.two's Avatar
SiRII's are called B16A's.
Old Apr 24, 2004 | 09:14 PM
eL's Avatar
eL
Anyone know the answer to my 2nd post?
I didnt really ask but what I need to know is if I am currently using an OBD1 ecu on my B16A2 without any modifications, how would that be possible if the b16a2 in the 99-00 Si is OBD2? Any help would be appreciated for this hybrid n00b.
Old Apr 24, 2004 | 09:17 PM
skip.two's Avatar
Default Re: (eL)
OBD2 to OBD1 converter? i'm not sure.
Old Apr 24, 2004 | 09:19 PM
HyBriDcxR's Avatar
Default Re: (eL)
Use a p28 if you have obd1.
That's what i'm using for now until i can get it chipped for my b16a2.
Old Apr 24, 2004 | 09:38 PM
Turbogixxer's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know the answer to my 2nd post?
I didnt really ask but what I need to know is if I am currently using an OBD1 ecu on my B16A2 without any modifications, how would that be possible if the b16a2 in the 99-00 Si is OBD2? Any help would be appreciated for this hybrid n00b.</TD></TR></TABLE>
You can run a obd two motor on obd one (even keeping all the sensors obd two) without a problem as long as you convert the harness (your civic obd one) or run a obd two integra harness
Old Apr 24, 2004 | 09:57 PM
eL's Avatar
eL
My next question should be... Which ECU SHOULD I be using?
Old Apr 24, 2004 | 09:58 PM
Default Re: (eL)
obd one is better for tuning and has less emission stuff than obd two
if the car is obd one
keep obd one
Old Apr 24, 2004 | 10:01 PM
eL's Avatar
eL
Default Re: (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">obd one is better for tuning and has less emission stuff than obd two
keep obd one</TD></TR></TABLE>
I know I should keep an OBD1, but which one exactly?
Old Apr 24, 2004 | 10:03 PM
Default Re: (eL)
I know I should keep an OBD1, but which one exactly?</TD></TR></TABLE>
sorry
what are you asking?
There is only one obd one
Old Apr 24, 2004 | 10:08 PM
eL's Avatar
eL
sorry
There is only one obd one</TD></TR></TABLE>
Only 1 OBD1 ECU?
Old Apr 24, 2004 | 10:09 PM
Kidnkorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, I have a B16A2 and I believe I'm using an 0BD1 ecu, I dont remember exactly which one it is but i'll look tomorrow. It's NOT the A2's ECU though. So I would need to know where the B16A2 I have came from in order to get the right ECU i'm guessing.</TD></TR></TABLE>
does it say B16A or B16A"2" on the block?
Old Apr 24, 2004 | 10:11 PM
eL's Avatar
eL
Default Re: B16A2, What do they come in? (Huggy Bear)
Says B16A2
Old Apr 24, 2004 | 10:34 PM
slammed_93_hatch's Avatar
you can drop a OBD2 motor with its originall harness right into your car and retain use of your stock "car harness". therfor leting you run an OBDI ecu with out any conversions.
and there is only one OBDI ecu for the 1.6 litter DOHC vtec motor, it came off of a b16a3, its virtually the SAME EXACT Motor.
now you could be running a chip'c ECU. mmm any one know the thread with the pictures of the ECU and how to identifi it??? there is a thread around here some were and the picture is always floating around. im pretty sure KATMAN (ht user name) is the guy who did the pic and write up.
Old Apr 24, 2004 | 11:15 PM
TwistedSI's Avatar
The bottom ends are all the exact same.
Old Apr 24, 2004 | 11:32 PM
Bong29007's Avatar
Default Re: (eL)
OBD1 for the B16A2, i just pulled out a B16A2 out of my wrecked '97 Sol and that's what it had
Old Apr 24, 2004 | 11:52 PM
TwistedSI's Avatar
I thought the 97 sol was OBD2? I could be wrong though.
Old Apr 24, 2004 | 11:57 PM
eL's Avatar
eL
Default Re: (TwistedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI &raquo;</TD></TR><TR><TD CLASS="quote">I thought the 97 sol was OBD2? I could be wrong though.</TD></TR></TABLE>
I was thinking the same thing.
Old Apr 25, 2004 | 01:06 AM
Default Re: (eL)
it is he is confused 96+ obdII
Old Apr 25, 2004 | 05:04 AM
2000CX's Avatar
Default Re: (slammed_93_hatch)
p30 should work also...i believe that is the stock usdm ecu that came in the sol's.
Old Apr 25, 2004 | 07:05 AM
DebutBobby's Avatar
Let Me End The Confusion...
OBD0
1988-1991 Civics, Integras, & Preludes
OBD1
1992-1995 Civics, Integras, & Preludes
OBD2a
1996-1998 Civics
1996-1999 Inegras
1996-2001 Preludes
OBD2b
1999-2000 Civics
2000-2001 Integras
