help me not suck at driving!!!!!
Old Apr 24, 2004 | 07:55 PM
98gsrTEG's Avatar
Default help me not suck at driving!!!!!
ok, i went to the track today for the first time turbo. i only got 2 runs in but they were pretty embarrising.
run#1 14.56@109.8mph and a 2.7 0 foot
run #2 14.57@111.4mph and a 2.6 60 foot.
these were done on falkin azinis on 20psi
car weighed 2635 with me in it and i weigh 175lbs. its a 98 gsr
my problem was that i couldn't give it full throttle untill 3rd gear without spinning the tires. also i have no clue how to launch this car now. i pulled better than stock times with my car when it was stock but this is totally different. i also have an 8lb flywheel to make things worse.
please i need some help, with my trap speeds i should be in the 12s i have never talked to anyone who has drag raced a turbo honda, and i can't really find any good advice from searching.
my next purchase will be some drag radials.
help me not suck!!!
Old Apr 24, 2004 | 07:59 PM
OEMJDM's Avatar
Default Re: help me not suck at driving!!!!! (98gsrTEG)
practice!
Old Apr 24, 2004 | 08:03 PM
RZcHatch's Avatar
well the best advice I can give you would have to be invest in a set of drag slicks. you would want 25.8.7-13 they would help alot. you can launch higher and keep it full throttle the whole time. yes you would have to do a burn out but you can learn that pretty easy with slicks. So hope the advice helped.
Old Apr 24, 2004 | 08:06 PM
MadnessRacing's Avatar
JUST PRACTICE AND IF YOU CAN TRY TO SLICK DOWN,AZENIS HOLDING 20PSI NO GOOD,
Old Apr 24, 2004 | 08:15 PM
98gsrTEG's Avatar
Default Re: help me not suck at driving!!!!! (MadnessRacing)
i don't really want to run slicks on stock alxes, thats why i am getting radials for now. but even then i don't know how to launch with turbo. how fast do you drop the clutch how much throttle to give it in first and second, what rpms to launch at. **** like that. i also had boost set to .4 bar in first, .5 in second and then .75 in third fourth and fith. by the time i am done with the run i am into fith already
i know the azinis suck for drag, its all i have right now. my radials are soposidly in transit right now
Old Apr 24, 2004 | 09:24 PM
u2civic1's Avatar
what do u mean azenis are bad at 20psi whats a good psi for azenis for track?
Old Apr 24, 2004 | 09:45 PM
98gsrTEG's Avatar
Default Re: help me not suck at driving!!!!! (u2civic1)
azinis are a budget road racing tire with a stiff sidewall. meaning you get tons of wheel hop. you want a softer sidewall for optimum grip when drag racing.
there is no psi were the azinis would be good for drag
Old Apr 25, 2004 | 06:06 AM
91civicDXdude's Avatar
turbos are hard to launch being that when the turbo hits full spool you break the tires loose like no other.
i was recently running on 23x7x13" road racing tires (partial slick with tall side wall) and even with a huge burnout which would make the tires really warm, i would burnout all through 1st and halfway down the track in 2nd.
1/8: 9.3@83mph 2.3 60'
Old Apr 25, 2004 | 06:57 AM
highbooster123's Avatar
Default Re: (91civicDXdude)
Your gonna break something running that much power and trying to hook up. I would leave the tires that you have on your car now until you get your drivetrain taken care of.
Old Apr 25, 2004 | 07:56 AM
streetlvlhatch's Avatar
Default Re: (highbooster123)
Hey i feel your pain about the lack of traction. I just turboed my car, and went to the track for one run on my 13in all season tires (175's). I ran 13.5 @110, and first and second were a joke. My 60ft's were better, but after 60 ft, it just let loose like a bitch. I am planning on getting some drag radials, but on steelies for now. My suggestion is to not go full throttle in first and second. I didnt when i did my run, even though they let loose. Try and keep them from not slipping and leting loose. Also about the launch, i just reved it to 3500 and slipped it real quick and got a 2,2 60ft. Just make sure you dont bog down. good luck!
Old Apr 25, 2004 | 10:32 AM
98gsrTEG's Avatar
Default Re: (streetlvlhatch)
i didn't give it full throttle untill 3rd gear, but i still lost traction like hell. here is my timeslip
r/t:1.121-i suck i know
60:2.601
330ft:6.954
et@594:9.425
1/8:9.828
1/8 mph:85.89
1000ft:12.331
1000 mph 98.02
1/4 e/t: 14.560
1/4 mph:111.60
as you can see my e/ts and speeds suck *** untill the 1000ft when my speeds become a little faster and then i end in a trap that should be producing low to mid 12's
Old Apr 25, 2004 | 10:54 AM
TEAMGENDAI's Avatar
Default Re: (98gsrTEG)
Keep practing and keep up the good work!!
95ITRJDM
Dec 9, 2011 12:16 PM
CRXherbie91
Jun 10, 2008 03:42 PM
Jason703Racing
Apr 13, 2008 07:10 AM
H22Stew
Feb 2, 2008 05:44 PM
NW94RS
Apr 3, 2002 09:35 AM
