engine miss
Old Apr 24, 2004 | 06:01 PM
JUSTIN WAITE's Avatar
Default engine miss
I have a 1993 honda accord 2.2 and from 1500 rpm to 2200 at light throttle my engine studders under hard throttle it seems fine i have new plugs wires cap n rotor and my valves are adjusted to spec please help
Old Apr 24, 2004 | 07:14 PM
Chiovnidca's Avatar
Default Re: engine miss (JUSTIN WAITE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUSTIN WAITE &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1993 honda accord 2.2 and from 1500 rpm to 2200 at light throttle my engine studders under hard throttle it seems fine i have new plugs wires cap n rotor and my valves are adjusted to spec please help</TD></TR></TABLE>
Sounds like your EGR ports may be plugged up. Try disconnecting the vacuum line to the EGR valve to see if it goes away.
Old Apr 24, 2004 | 07:46 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUSTIN WAITE &raquo;</TD></TR><TR><TD CLASS="quote">thank you ill try that tomorrow thats the first time any one had a reasonable answer except replace everything till it runs right</TD></TR></TABLE>
Yea, there's usually a way to diagnose most problems. Throwing parts at them can get expensive.
Old Apr 25, 2004 | 11:48 AM
Default Re: engine miss (Chiovnidca)
i tried what you said it worked now i have check eng light changed the egr and still no change why when i unhook the tube is it ok the solenoid does not hold vacuum so i think its good what do you think
Old Apr 25, 2004 | 01:03 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUSTIN WAITE &raquo;</TD></TR><TR><TD CLASS="quote">i tried what you said it worked </TD></TR></TABLE>
Well that verifies it, your EGR ports are clogged up. There's a good thread on here somewhere telling how to clean them out.
Old Apr 25, 2004 | 07:55 PM
hello again i checked out all the egr threads just wondering is it a good idea to remove the plugs. are they a threaded plug or like a freeze plug.one more thing how do you get the crap you break loose out of the intake so is not to cause any damage or should i pull the intake and soak it in a carb tank or is that going overboard
Old Apr 26, 2004 | 03:18 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUSTIN WAITE &raquo;</TD></TR><TR><TD CLASS="quote">hello again i checked out all the egr threads just wondering is it a good idea to remove the plugs. are they a threaded plug or like a freeze plug.one more thing how do you get the crap you break loose out of the intake so is not to cause any damage or should i pull the intake and soak it in a carb tank or is that going overboard</TD></TR></TABLE>
Drill a hole in them and use a slide hammer to get them out. Poke out the holes then you can use a vacuum cleaner to get some of the pieces out. Some carb cleaner should take care of the rest.
GetawayInMoscow
Nov 21, 2006 07:57 AM
(__________)
May 22, 2005 06:34 PM
Icey112
Dec 4, 2004 10:00 PM
99WS6LS1TA
Jun 15, 2004 10:07 PM
