tech 43 ls cranked b16 piston kits
well i was just wondering if you could do a similar piston kit using a ls crank and have the same rod stroke ratio, but make a higher compression piston? just really curious cause i really like your set up, but i just wanted higher compression or what would you sugest to make more power using a b16 block and a ls crank, and this is for a all motor set up
Ak_ef9
May 6, 2007 10:57 PM
