What kind of injectors???
so you want us to tell you what size injectors to get based on what engine you have.....
also, if you think $260 for the mostvital part of you turbo system is "steep" you are in for a big surprise.
*EDIT* i just scrolled through the eg forum and saw about 5 posts from you. get off your lazy *** and do some research. you have no idea what you are talking about. please use the search function.
THe point of these forums are to get opinions and ideas from others. It is ******** like you that have to flame everything up and be a dick. If you don't like the subject on a post, do everyone a favor and shut the hell up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">so you want us to tell you what size injectors to get based on what engine you have.....
Wow, instead of just telling him some cheaper alternatives, like DSM injectors that YOU used to use on your own damn car you have to go out of your way to try and embarass him
There is no reason anybody with a mild to moderate turbo setup can't use dsm(laser/talon/eclipse)turbo injectors, which go for between 50-100 dollars depending on quality and size(390/440/450)
See Are X
Dec 14, 2005 07:29 AM
