Grr header cracked....repairable?
Old Apr 24, 2004 | 04:38 PM
CRiSP's Avatar
Default Grr header cracked....repairable?
So my exhaust has been getting louder and louder lately, so today I was checking it out and low and behold it was cracked, pretty badly. Here are some pics.
So what do you guys think? Repairable? I know the flow will probably not be the same if it is repaired. If your wondering its a Spoon header about 2 years old. I was told by some friends I might have motor mounts going bad cause this might look like a stress fracture. Give me some of your opinions please..
Old Apr 24, 2004 | 04:39 PM
Bbasso's Avatar
Default Re: Grr header cracked....repairable? (CRiSP)
Fixable for sure!
Call me aty home.
Old Apr 24, 2004 | 04:41 PM
Opie's Avatar
Wow how's that for deja vu Rob
Old Apr 24, 2004 | 04:42 PM
CRiSP's Avatar
Default Re: Grr header cracked....repairable? (Bbasso)
dam Rob...you are fast with the replies. I already spoke with Rodey. He might be doing some welding tomorow so hes going to call me back when he finds out.. Good news!..just found my stock cat so I can at least run the stock header for the time. ohh and I dont know you home number.
Old Apr 24, 2004 | 04:47 PM
ZygSpeed's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">Wow how's that for deja vu Rob </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=833032
Definately repairable.
Old Apr 24, 2004 | 04:50 PM
CRiSP's Avatar
Default Re: (zygspeed)
Ohh wow Im not a frequent here so I didnt know this happened to someone else. Any inputs on what might have caused this? there is no damage to anyplace else on the header, my ITR has a stock suspension so I am ok in most situations for ground clearance.
Old Apr 24, 2004 | 05:13 PM
1GreyTeg's Avatar
Default Re: (CRiSP)
Rob, the Spoon header doesn't have a support at the rear as the stock and JDM OEM one do and most likely cracked under stress and whatnot. It has nothing to do with you hitting anything, more like the heat and twisting stress and lack of support as the engine moves when running.
Best of luck, see you soon.
Anton
Old Apr 24, 2004 | 05:26 PM
JDMpianoguy's Avatar
Default Re: (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Rob, the Spoon header doesn't have a support at the rear as the stock and JDM OEM one do and most likely cracked under stress and whatnot. It has nothing to do with you hitting anything, more like the heat and twisting stress and lack of support as the engine moves when running.
Anton</TD></TR></TABLE>
now i'm guessing my old header that Dr.Cortez had now may have been heading to the same destiny even before I hit that dip in road
Old Apr 24, 2004 | 05:30 PM
B2FiNiTY's Avatar
Default Re: (JDMpianoguy)
Interesting. I'll be sure to check and listen to my header area more often.
Old Apr 24, 2004 | 05:31 PM
SCGsROCK!'s Avatar
What kind of noise was it making ? I have a problem with the header in my GSR making an annoying sound at 3500 RPM's and im wondering if my header is cracked as well.
Old Apr 24, 2004 | 05:33 PM
Default Re: (SOCDC2)
what kind of noise was it...an air leak sound like above or a rattle?
Old Apr 24, 2004 | 05:52 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOCDC2 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of noise was it making ? I have a problem with the header in my GSR making an annoying sound at 3500 RPM's and im wondering if my header is cracked as well. </TD></TR></TABLE>
If that is kind of a buzzing rattling sound around 3,500 to 5,000 rpm and relatively intermittent, it sounds like the heat shields. Get under and take a look at the heat shields. In the 94 to at least the 97 to 98's there was a recall for the heat shields because they worked their way loose and rattled all around.
I had that work done on my 94 LS when I still went to the dealerships.
My first R didn't have that rattle/issue but when I got my second R I knew what the sound was right away and Rodney was nice enough to crawl under and rip them right off. No more buzz now.
Old Apr 24, 2004 | 05:53 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMpianoguy &raquo;</TD></TR><TR><TD CLASS="quote">what kind of noise was it...an air leak sound like above or a rattle?</TD></TR></TABLE>
I'd expect his leak to be gettin pretty loud.
Old Apr 24, 2004 | 06:19 PM
i agree with the heatshield problem...i've also seen some guys cats go bad after a while and start rattling inside.
Old Apr 24, 2004 | 09:16 PM
..::91TEG-G2::..'s Avatar
i have a 91 ls.. and mine rattles.. but i think its cuz rocks got up in the little holes of the heat shield somehow, would it be safe to take them off, or would i have to worry about a plastic bag flying underneath the car from wind and melt onto my cat?
Old Apr 24, 2004 | 11:16 PM
CRiSP's Avatar
Default Re: (..::91TEG-G2::..)
The noise will be a fairly noticable noise. It will pretty much sound like an exhaust leak. Originally I thought the gasket may have fallen apart or some loose, so that is why I was originally down there checking things out. After spending the past 2 hours working on getting off the dam rusty bolts I am not back to stock for the time being. I could have lived with the exhaust leak sound but I dont want to cause any further damage to the header so its off awaiting surgery.
-Rob
Fink29
15
May 18, 2009 03:15 PM
TurboHatchB16
Dec 22, 2008 07:32 PM
espanol
May 19, 2008 05:47 PM
eg6hatch
15
Nov 26, 2004 09:12 AM
v00tecsi
Jun 30, 2003 02:14 PM
