Need some help with buddys 94 VTEC (advanced timing)?
Old Oct 31, 2001 | 11:20 AM
infamousALLMTR's Avatar
Default Need some help with buddys 94 VTEC (advanced timing)?
can you advance a vtec preludes timing at all, I read that you can but I dont see how on the engine. Any info is appriciated
Old Oct 31, 2001 | 11:29 AM
JG Luder's Avatar
Default Re: Need some help with buddys 94 VTEC (advanced timing)? (Redracinghart)
loosen the three bolts on the distributor, and then turn it. Have that timing gun hooked up and ready.
Old Nov 2, 2001 | 07:47 PM
Default Re: Need some help with buddys 94 VTEC (JG Luder)
yes i can see that but there is no indicator on the block and no white or red mark, and i just dont want to turn the distibutor.
Old Nov 3, 2001 | 08:27 AM
John's Avatar
New User
Default Re: Need some help with buddys 94 VTEC (Redracinghart)
score your own mark on the distributer flange to use as a reference point for when you rotate your distributer... just remember that you are going to be affecting the ignition timing, not the cam timing (mechanical timing)...
Pancho2193
Mar 13, 2013 10:38 AM
broadway
Mar 12, 2007 05:17 PM
bananas
Apr 16, 2004 01:21 PM
joestud
Jul 9, 2002 11:49 PM
