cam gears
Old Oct 31, 2001 | 11:08 AM
HondaNewbie's Avatar
Default cam gears
What brand is good for accords? I've checked out some AEM cam gears and they look pretty good...also, if anyone is selling let me know.
Old Oct 31, 2001 | 09:01 PM
John's Avatar
New User
Default Re: cam gears (HondaNewbie)
that's what i use.... but honestly, i don't think any one brand is better than the other (just like intakes)...
Old Nov 1, 2001 | 07:35 AM
4doorH22's Avatar
You'll want as many bolts as possible on the gear. AEM only has 3, my AEM gear slipped on me twice, I think it may have ruined my F22. Unothodox Racing makes a 5 bolt gear (the Ultra TR), but it's damn pricey. Crower makes a 4 bolt one that looks decent. http://www.unorthodoxracing.com http://www.crower.com
HTH
[Modified by 4doorH22, 3:39 PM 11/2/2001]
Old Nov 1, 2001 | 07:51 AM
urbanlegend21's Avatar
New User
Default Re: cam gears (4doorH22)
What difference do the bolts make?
Old Nov 1, 2001 | 08:11 AM
4doorH22's Avatar
Default Re: cam gears (urbanlegend21)
More bolts = more torque to keep the toothed part of the cam gear from slipping relative to the body of the cam gear.
Old Nov 2, 2001 | 09:31 AM
cool thanks man, I shall check them out......crower is probably best bang for my buck?
[Modified by HondaNewbie, 1:32 PM 11/2/2001]
Old Nov 2, 2001 | 09:40 AM
wow, the unorthodox racing one sounds really great. Price doesn't look too insane, $180. Hopefully I can find a coupon somewhere and get a discount on groupbuy. Does anyone have personal experience from this cam gear? I would like to hear some good news
Old Nov 2, 2001 | 10:03 AM
4doorH22's Avatar
Oh, $180 isn't too bad, for the DOHC H22 Ultra TRs they want 500+ bucks. Half a thousand dollars for 2 cam gears??!?!
Anyways, JG Luder on this board uses UR cam gears.
I wanted the Crowers until I saw the URs, but at that price I'll probably go with the Crowers.
Old Nov 2, 2001 | 11:29 AM
cam sprockets are same thing as cam gears?
Old Nov 2, 2001 | 11:33 AM
UR's ultra TS's have 4 bolts...not 5
Old Nov 2, 2001 | 11:36 AM
4doorH22's Avatar
Yes, the TS has 4, I'm talking about the TR, which has 5.
Oops so I typed TS way above. I've always meant the TR.
As far as I know cam sprockets and cam gears are one-and-the-same.
[Modified by 4doorH22, 3:40 PM 11/2/2001]
Old Nov 2, 2001 | 12:51 PM
oh ok, cool. Would you recommend the TS or TR...considering price factor.
the tr's are probably over $200
Old Nov 2, 2001 | 12:55 PM
4doorH22's Avatar
I wouldn't recommend anything I've never tried, but I'd say it's a safe bet you can't go wrong with either the UR TS, TR, or the Crower.
Old Nov 2, 2001 | 01:02 PM
John's Avatar
New User
well, cam gears won't slip if you torque the bolts down enough... and it's not that difficult kids... i've been using an AEM cam gear for over 2.5 years now... and i've never had a problem... so maybe more bolts will save you from negligence, but the best way to avoid any slippage of your cam gear is to avoid negligence... right?
Old Nov 2, 2001 | 01:15 PM
4doorH22's Avatar
Default Re: cam gears (DunReit)
I wouldn't doubt the mechanic that initially put mine on and torqued the bolts was negligent, but I still think the more bolts the better for shear piece of mind.
Old Nov 2, 2001 | 03:22 PM
HoNdAeX11's Avatar
New User
Does the Accord engine fit in the B series type of the cam sprockets. or is it F series cause of the F22A or F22B, i always get confused between all the engine title things.
Old Nov 2, 2001 | 08:10 PM
Default Re: cam gears (HoNdAeX11)
accord engines are F series
Old Nov 2, 2001 | 09:44 PM
has anyone else had problems with AEM?
Old Nov 3, 2001 | 05:21 AM
HoNdAeX11's Avatar
New User
skunk 2 sells a 6 bolt cam gear for about $120 for a 90-97 Accord
Old Nov 4, 2001 | 07:56 PM
aw, too bad I got the 6th gen...
Halo
Oct 21, 2016 07:29 PM
The Si
Feb 22, 2007 10:36 PM
allicedout
Jun 17, 2004 04:57 PM
Wes90civic
Feb 1, 2004 01:19 AM
jabroni95gsr
Nov 1, 2001 03:20 PM
