First oil change - which engine oil?
Old Apr 24, 2004 | 01:02 PM
HUBB's Avatar
Default first oil change...00 JDM ITR...which oil?
im changing the oil in my 00 B18C..jdm ITR...and ran the first couple thousand miles on regular CASTROL GTX 5w-30....what oil and weight do u guys reccomend i run in for my next 5 quarts...synthetic, regular, 5w, 10w, MOBIL 1, ROYAL PURPLE..etc....PS: i drive my car hard
Old Apr 24, 2004 | 01:36 PM
nightrider's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (HUBB)
castrol gtx 5w-30 all the way here.
Old Apr 24, 2004 | 01:40 PM
HUBB's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (nightrider)
i was hearing from my EG homies that i should run some synthetic...MOBIL 1...AMSOIL...etc..
Old Apr 24, 2004 | 01:42 PM
rated_r's Avatar
valvoline
Old Apr 24, 2004 | 01:53 PM
HUBB's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (rated_r)
ive heard good **** bout the VR1 stuff or whatever
Old Apr 24, 2004 | 02:05 PM
Chris's Avatar
I know a guy who races his ITR using Chevron 5W 30
Oil is oil.
And the oil subject=old
Old Apr 24, 2004 | 02:58 PM
ArmyGreenITR's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (Chris)
Mobil1 10-30,though some will dissagree ive never had a problem with it.
Old Apr 24, 2004 | 03:00 PM
00MRSi's Avatar
You can continue to run the regular Castrol GTX 5w-30, good stuff. If you want a decent, easily accesible synthetic that's affordable, try Castrol Syntec 5w-30. Mobil 1 is decent, but you might have oil consumption like many other people experience..
I've heard good things about Valvoline synthetic also..
Old Apr 24, 2004 | 03:44 PM
HUBB's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (00MRSi)
aight im out...thanks for the input...ill probably try some synthetic of some sort...peace out
Old Apr 24, 2004 | 04:40 PM
Opie's Avatar
The anwser is in the Search link up in the corner
Old Apr 24, 2004 | 04:51 PM
mikehonda's Avatar
Default Re: (opie)
It's your choice really. Castrol, Valvoline are race proven and don't seem to disappear. I know many that have suffered oil loss when useing Mobil 1, Redline, NEO. I wouldn't recommend 5w-20/30, it simply isn't thick enough.
mikehonda: who stuck with Castrol Syntec 10w-30, and da B18C5 doesn't use a drop
Old Apr 24, 2004 | 04:52 PM
nightrider's Avatar
it seems like you just wanted to know what type of oil you should use so you won't have to worry about other stuff. that's not it man. i'll use no name oil and still be fine as long as i change & check my oil.
Old Apr 24, 2004 | 05:00 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HUBB &raquo;</TD></TR><TR><TD CLASS="quote">im changing the oil in my 00 B18C..jdm ITR...and ran the first couple thousand miles on regular CASTROL GTX 5w-30....</TD></TR></TABLE>
This is the first time you're changing the oil in a four-year-old car?
Old Apr 24, 2004 | 06:50 PM
jond's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (nsxtasy)
M1 5w30 - winter
M1 10w30 - summer
Old Apr 24, 2004 | 07:02 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HUBB &raquo;</TD></TR><TR><TD CLASS="quote">and ran the first couple thousand miles on regular CASTROL GTX 5w-30 </TD></TR></TABLE>
keep on running 5w30
Old Apr 24, 2004 | 07:03 PM
Padawan's Avatar
Darth ModerVader
Default Re: first oil change...00 JDM ITR...which oil? (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">M1 5w30 - winter
M1 10w30 - summer</TD></TR></TABLE>
The viscosity of both of these should be nearly identical once they reach operating temperature, so there shouldn't be any real problem using the 5W-30 year round.
Old Apr 24, 2004 | 07:04 PM
vtec.dc2's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
The viscosity of both of these should be nearly identical once they reach operating temperature, so there shouldn't be any real problem using the 5W-30 year round. </TD></TR></TABLE>
that, and sometimes you get better specs with 5w30
Old Apr 24, 2004 | 07:45 PM
nbaonabc's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (vtec.dc2)
I have a 99 jdm itr swap and been using mobil 1 with no problem and running great. 10-w40
Old Apr 24, 2004 | 07:46 PM
Justin Klemgold's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi &raquo;</TD></TR><TR><TD CLASS="quote">You can continue to run the regular Castrol GTX 5w-30, good stuff. If you want a decent, easily accesible synthetic that's affordable, try Castrol Syntec 5w-30. </TD></TR></TABLE>
Castrol syntec is not a synthetic oil unless you get the German made kind...which is green....Castrol likes to charge their customers synthetic prices for a non synthetic Castrol Syntec....great company!
Old Apr 24, 2004 | 07:59 PM
HUBB's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (Justin Klemgold)
uuuh actually its in a 93 hatch ....i wish i had a 2000 J-spec ITR
Old Apr 25, 2004 | 06:42 AM
nsxtasy's Avatar
H-T Order of Merit
So this is the first time you're changing oil in a four-year-old engine? I hope you got the engine used within the past six months, and the engine oil was previously changed many times by the previous owner. (Or, you got the engine new and it was sitting on a shelf for 3-4 years.)
Don't tell me you've been using that engine for four years without changing the oil. Please don't tell me that.
Old Apr 25, 2004 | 06:43 AM
nsxtasy's Avatar
H-T Order of Merit
The ITR owner's manual recommends 5W30 at all temperatures. Above freezing, 10W30 is acceptable, but 5W30 is still preferred.
Old Apr 25, 2004 | 07:00 AM
00MRSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">
Castrol syntec is not a synthetic oil unless you get the German made kind...which is green....Castrol likes to charge their customers synthetic prices for a non synthetic Castrol Syntec....great company!</TD></TR></TABLE>
.RJ said that last week also. Doh!! I forgot.. Those bastards!! So the Castrol Syntec they sell us here is really a synthetic blend?
Old Apr 25, 2004 | 10:53 AM
Two_K Si's Avatar
.RJ said that last week also. Doh!! I forgot.. Those bastards!! So the Castrol Syntec they sell us here is really a synthetic blend? </TD></TR></TABLE>
Well, lets just say that it is no better then GTX. I wish more people would be informed that they are paying for a highly refined dino oil, instead of a true synthetic like mobil 1. Europe gets much higher quality full synthetic oils from Castrol, but not us here in NA. Castrol
Old Apr 25, 2004 | 02:10 PM
TypeRuz's Avatar
Default Re: first oil change...00 JDM ITR...which oil? (Two_K Si)
my ITR drinks Mobil 1. this is actually a recent topic i've posted. basically, all VTEC's...especially ITR's and S2000's drink it up. probably has to do with the extreme high revving.
i'm switching to Amsoil 5W30 in a couple weeks. supposed to be the best stuff. i'm hoping my R isn't thirsty for it like the M1.
my brother has a 2000 Prelude and has the same problem with M1. he recently switched to Castrol Syntec 5W30. we're waiting to see if the "easily-accessible" Castrol lasts as long as the "harder to find" Amsoil.
then we'll decide which oil we'll stick with. i'll post up the results when we know what's up.
