crank seal keeps LEAking.......
Old Apr 24, 2004 | 10:08 AM
sohcVtec_1's Avatar
Default crank seal keeps LEAking.......
this is the second time i've changed the cranck seal, but for some reason it keeps leaking. Is this because my cranck is moving.....? Do i have a bad motor......?
It had the LX motor non Vtec, I replaced with EX Vtec....could this play a role in
this problem....any info would be nice.
thanx,
Old Apr 24, 2004 | 10:37 AM
Oh Crap's Avatar
you have to make sure there are no scars/scuff marks on the crank shaft before installing the crank seal. If there are, lightly sand it down with 2000 grit until the burrs are gone.
Old Apr 24, 2004 | 01:02 PM
sohcVtec_1's Avatar
Default Re: (Oh Crap)
I had the DEALER do the seal......wouldn't they know if it need to be sanded...?
Old Apr 25, 2004 | 11:26 PM
blueeg's Avatar
Default Re: (sohcVtec_1)
nope.
Old Apr 26, 2004 | 07:29 AM
FlexW99's Avatar
dood,
i have an ex accord with the vtec motor f22b. apparently, they was a recall on that type of problem. mine leaks, and after getting under there and looking, it does look like its from the crankseal...
dunno if your leak is like mine but mine seems to leak only when the car has been shutoff...when i had the motor running and looked ...there was no leak...
Im just gonna let it leak....its not a fun job...
Old Apr 26, 2004 | 02:46 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcVtec_1 &raquo;</TD></TR><TR><TD CLASS="quote">I had the DEALER do the seal......</TD></TR></TABLE>
How long has it been. If it hasn't been very long they should repair it again. (hopefully right)
dahmuno
Dec 10, 2008 02:36 PM
b18c4door
Nov 12, 2007 01:14 PM
GaRn
Dec 22, 2005 09:09 PM
SwedBoy2999
Mar 22, 2004 07:44 PM
