brake lights?
Old Apr 24, 2004 | 09:16 AM
crlexus's Avatar
Default brake lights?
I got pulled over the other night and the officer told me that my brake lights were stuck on. When I got home to check it out, sure enough, while my headlights were turned on, my brake lights were stuck on as well. Also, when I hit the brake pedal, my parking lamps came on. Does anyone know what might be causing this and how I might fix it?
Old Apr 24, 2004 | 11:33 AM
Kasper.'s Avatar
Default Re: brake lights? (crlexus)
Id say your looking at 3 things, A bad Brake pedal switch that is staying engaged and not allowing the brakes to open the brake light circuit in turn killing power ot the brake lights.
A cross short, somwhere you've got to wires that are feeding into each other signal and its going haywire. A bad multifunction switch can do this too....
Or youve got a plain and simple short to power......does your car leak? If so I connector might be gunked up and covered in water, like around your taillight gaskets or are any of your lights cracked?
Old Apr 24, 2004 | 11:47 AM
crlexus's Avatar
Default Re: brake lights? (Kasper-EF8)
My brake lights used to get filled up with water. So what do i look for there? Also, would that explain my parking lamps as well?
chighizola9
Jul 20, 2013 01:46 PM
brndnhlcmb
May 1, 2010 08:44 PM
RanCRX
Jun 9, 2008 07:35 PM
mr. carpenter
Mar 13, 2005 05:14 PM
94TealGSR
Oct 25, 2002 11:41 AM
