emissions testing... did you blow clean?
Old Apr 24, 2004 | 09:12 AM
twkdCD595's Avatar
Default emissions testing... did you blow clean?
Yeah so I am going to try to pass emissions here, which is gay... mo should not have this ****. I luckily have a hand up on them cause I use to be a certified inspector for them a few years ago.. but I need a new ecu first for chipping before I can do that.
Anyways... SERIOUSLY who has been able to get past emissions <U>turbocharged</U>. Did you have a catalytic converter? what fuel management, boost, etc, etc?
Old Apr 24, 2004 | 11:32 AM
twkdCD595's Avatar
Default Re: emissions testing... did you blow clean? (twkdCD595)
So no one has emissions tested?
Cause I bet I can not only pass... but I bet I could do it without the catalytic converter.
Old Apr 24, 2004 | 11:40 AM
TurboEH2's Avatar
so do it. then tell us how u did it.
Old Apr 24, 2004 | 11:57 AM
twkdCD595's Avatar
Default Re: emissions testing... did you blow clean? (VTECschmetec)
way to increase your post count... so yeah I was looking for others who have had passed/ failed, and what the situation was?
Old Apr 24, 2004 | 12:09 PM
TurboEH2's Avatar
i wasnt trying to increase my post count. all i was saying is ur trying to make a contest out of this by saying "i bet i could" and i was simply saying do it. then talk about it.
Old Apr 24, 2004 | 12:27 PM
Sohc Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECschmetec &raquo;</TD></TR><TR><TD CLASS="quote">i wasnt trying to increase my post count. all i was saying is ur trying to make a contest out of this by saying "i bet i could" and i was simply saying do it. then talk about it. </TD></TR></TABLE>
I agree...go do it and tell us how you did it..because I've never heard of anyone doing it before and passing.
Khoi
Old Apr 24, 2004 | 12:55 PM
twkdCD595's Avatar
whatever your reply was so generic... I am not hosting a contest... you see me giving away prizes. how is asking for input on a subject a contest.
I was asking about people emissions experiences... although I am not worried about my own coming up.
and if you have never heard of anyone turbocharged passing emissions before... your sadly mistaken.
Old Apr 24, 2004 | 02:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">
and if you have never heard of anyone turbocharged passing emissions before... your sadly mistaken.</TD></TR></TABLE>
Ok......then tell us how you pass emissions with a boosted motor already! I want to know atleast, and Im sure there are other people who want to know.
Khoi
Old Apr 24, 2004 | 03:05 PM
MikeMAN's Avatar
post retracted
Old Apr 24, 2004 | 03:45 PM
DaX's Avatar
DaX
Loved
Community Favorite
In the counties in GA [metro ATL anyhow] there is no visual inspection, only a sniffer. I haven't gone to get tested while boosted yet, but I don't see why you couldn't pass turbocharged if you have a good tune. Also, every time I got tested, they never really wound out the RPM's, so I don't know if they'd even really get into boost.
Old Apr 25, 2004 | 10:47 PM
red_sir's Avatar
Default Re: (DaX)
I've failed 4 times now. I'm running a 3 inch carsound cat. I'm going to try to tune it to a perfect 14.7 across the board before I go again. If that doesn't work then I guess it's time for a new cat.
I datalogged one of the tests and they took my car up to about 4psi. The noob driving my car didn't know how to drive.
twkdCD595: got any tips on passing emissions with a turbo car?
Old Apr 26, 2004 | 12:49 AM
integrx's Avatar
New User
Default Re: (red_sir)
well if you put your stock cat back on, that would help alot. Here in CA, you probably won't pass unless you have the stock cat on.
Old Apr 26, 2004 | 04:48 AM
J337_UNIT's Avatar
Default Re: (integrx)
it helps to know someone personally who does inspections
Old Apr 26, 2004 | 05:11 AM
turboteg96's Avatar
Default Re: (J337_UNIT)
Ok, I passed emmisions with my turbo teg. We have no visual, I simply mated the stock exhaust to the downpipe, Cat and all. Warmed up the engine, and explained to the kid not to go into Boost because you will run rich if you go into boost.
I passed with better results then my 88 Accord.
backinblue92
Sep 29, 2015 07:40 PM
Cloneufc
Oct 24, 2008 04:28 PM
FuNkDrSpOt
10
Dec 7, 2006 11:55 PM
SmogTech01
Aug 2, 2005 11:24 PM
mongoliandonuts
Aug 26, 2004 05:07 PM
