B20 <-- --> B18A/B compatibility
Guys what spark plugs and oil filter should i use for a B20Z? Should they be the same as a b18a/b even if they have different part numbers? Seems like they have less parts for the b20 than the b18a/bs. TIA.
Alot of things are the same between the two including I believe the spark plugs but if the part numbers are different I would get the part for the b20; you never know it may be an important difference.
The funny thing is, i looked at bosch's website and it lists the same plug for a b18a, b18b, and b20b/z. Other manufacturers however have different part numbers. I went with bosch platinums.
Same goes with oil filters. I belive though that most hondas share the same oil filter. Oh well.
