Spark plug wires?
Old Apr 24, 2004 | 05:31 AM
BigDawwg6969's Avatar
Default Spark plug wires?
Alright, i'm cruisin around Sandusky when all of a sudden, my car starts missin big time. So I stop at my aunt's shop and pop the hood. For some friggin reason, the #4 cylinder's spark plug wire popped loose so I just reattached it. Next day was going to get on the on ramp onto RT.2 and it does it again. Same missin, same wire, why is this doing this?
Old Apr 24, 2004 | 05:58 AM
HT Chaplain's Avatar
Loved
Default Re: Spark plug wires? (BigDawwg6969)
The clip that clips onto the spark plug must be worn out or the boot is all stetched out. Sound like it's time to get new ones
Old Apr 24, 2004 | 08:59 AM
krazie1's Avatar
BANNED
Default Re: Spark plug wires? (legutki)
correcto mondo
that is ur answer
had the same problem a while back
Old Apr 24, 2004 | 09:40 AM
ijjz's Avatar
Or its the spark plug hole gasket for the cover. I had the same problem with two sets of MSD spark plugs. Finally when I redid those gaskets, they stopped popping out.
Old Apr 24, 2004 | 11:37 AM
Kasper.'s Avatar
Default Re: Spark plug wires? (ijjz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ijjz &raquo;</TD></TR><TR><TD CLASS="quote">Or its the spark plug hole gasket for the cover. I had the same problem with two sets of MSD spark plugs. Finally when I redid those gaskets, they stopped popping out. </TD></TR></TABLE>
Thats what I was gonna say, this can also be had due to oil leaking from the spark plug o-rings and making a very lubed up spark plug wire easy to pop out.
Old Apr 26, 2004 | 12:49 AM
MR5sARECOOL's Avatar
Default Re: Spark plug wires? (Kasper-EF8)
if theres no oil leak, just push the wire till the metal connector comes out and squeeze it a little.
Old Apr 27, 2004 | 06:28 PM
Default Re: Spark plug wires? (MR5sARECOOL)
thanks to all that replied, i will get the car in the garage and try these ideas.
crvtt717
May 11, 2007 04:24 AM
JDM_SOHC
Apr 30, 2007 02:24 PM
eseries07
Honda Civic (2001 - 2005)
Oct 26, 2006 11:28 AM
lethalgsr32
Dec 31, 2005 03:50 PM
bey
May 5, 2003 10:18 AM
