Speedometer seems off
Old Apr 23, 2004 | 10:26 PM
alexb16hb's Avatar
Default Speedometer seems off
hey guys. I I just put a b16 in my 95 civic cx and the speedo seems way off. Like on the highway doin what I think should be 55-60 speedo reads higher. Any help would be appreciated. Thanks
Old Apr 23, 2004 | 10:27 PM
DAguyLS's Avatar
make sure your VSS didn't come loose.
It's the sensor that goes into the top of your tranny.
this should help, if it doesn't then get a new Vehicle Speed Sensor
Old Apr 23, 2004 | 10:29 PM
alleyezonme's Avatar
Default Re: Speedometer seems off (alexb16hb)
did you change the tire size?? cause that can mess it up cause if you go from a 13" to a 17" it will be off b/c the distance the car travels at one revolution of a tire on a 13 tire will be far less than that of a 17. the speedo is measured at the tranny or axle or something so one axle revolution with a 17" tire will travel farther then with a 13 on there. hope im clear it is kinda hard to explain.
5STAR3's Avatar
Default Re: (slamdcivic)
probably because it is off.
i had the same problem, get it calibrated
Old Apr 23, 2004 | 10:31 PM
DAguyLS's Avatar
Default Re: Speedometer seems off (bumpincivic20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumpincivic20 &raquo;</TD></TR><TR><TD CLASS="quote">did you change the tire size?? cause that can mess it up cause if you go from a 13" to a 17" it will be off b/c the distance the car travels at one revolution of a tire on a 13 tire will be far less than that of a 17. the speedo is measured at the tranny or axle or something so one axle revolution with a 17" tire will travel farther then with a 13 on there. hope im clear it is kinda hard to explain.</TD></TR></TABLE>
naah you explained it well man
Old Apr 23, 2004 | 10:32 PM
alexb16hb's Avatar
Default Re: (envision2teg)
yea I know about the wheel sizes and that is definatly not it no 17s hear. I am on 14s. So that is going to the VSS what did you mean by calibrating it or should I just check too see if it is tight
Old Apr 23, 2004 | 10:51 PM
DAguyLS's Avatar
just wiggle it and see if it feels loose, if it is tighten it up
Old Apr 23, 2004 | 11:25 PM
alexb16hb's Avatar
thanks guys hopefully this will do it
Old Apr 23, 2004 | 11:58 PM
chronodyne28's Avatar
Default Re: (alexb16hb)
am i the only that that didnt have to adjust anything when i bought 17's?
ge_itr
Sep 19, 2007 05:46 PM
rasinhell
Jan 23, 2007 12:51 AM
Coldness
May 30, 2006 02:09 PM
jerm001
12
Apr 2, 2006 03:20 PM
ludewithanh22
Jun 26, 2005 02:16 AM
