Need help with 1989 LXi check engine light
...then hop on over to this excellent discussion in the archive like I did -- https://honda-tech.com/zerothread?id=386394
Hi everybody. Nice forum here. Tried to search out some CEL answers before posting but I wasn't able to find much information for 1989 unfortunately. That is until I typed lxi into the search engine and found "89 check engine". 1989 was where I was coming up short. Since the search engine doesn't allow '89' as a two character filter, and because it doesn't match partial numbers to 1989, it wasn't until now that I discovered . . .
"The Code 6"
88' -89' Accord LXi Will not start when hot (code 6) TW Sensor (R&R) 263008 $ 29.50
Description:
For the second time this week, my check engine light continued to stay on after starting the car; before shifting out of park. It goes off and stays off after restarting the car a couple of times. The car drives fine. I tightened my gas cap about a quarter turn tonight.
From Atlanta, GA
Rydog
Modified by rydog at 9:28 AM 4/24/2004
"The Code 6"
Description:
From Atlanta, GA
Rydog
Well after looking at my ECU's LED, it flashes 13 short times and then repeats.
According to the code charts on HybrdGarage, this means a defective BARO sensor.
Any of you guys know what this is and how serious of a problem it is? How much it will cost to fix?
harms_is_back
29
Sep 6, 2011 09:54 PM
