Leaky Accord
Old Apr 23, 2004 | 09:11 PM
FlexW99's Avatar
Default Leaky Accord
Hey fellaz..
Bought a 94 Accord, as my civic is gettin rebuilt for some boost...anyway..
love this accord..very comfy, nice ride, etc...but it leaks...
now i know many wont be able to decipher the problem...and i just havent had any time to get under the car and see where its leaking..but maybe some educated guesses could help me out...
now, 1st, it leaks oil. I checked under the car..looks like the oil pan gasket (fingers crossed)...2nd, coolant leaks...not sure where this is leaking from...I have no heat....I put some coolant/antifreeze in..and the heat comes on, but goes back cold because the motor spat out the coolant i just put in..the good thing is is that it leaks pretty much right away. Now what I dont understand is how could the car not be overheating if its leaking coolant?....I will say, beyond those 2 factors, the engine runs beautifully, idles nice, revs high, shifts smooth..
When i check the oil, the oil is a nice golden color (because its constantly being filled I presume) but no coolant in oil is evident....so thats good...
any thoughts?...
Old Apr 24, 2004 | 07:30 AM
accordmurf's Avatar
Default Re: Leaky Accord (FlexW99)
your oil leak may be the camshaft seal or the crankshaft seal, there was a recall for your car that ended last yeat for that, if thats not it, it will be pretty soon
Old Apr 25, 2004 | 08:07 PM
FlexW99's Avatar
Default Re: Leaky Accord (accordmurf)
hey bro,
threw the car on a lift, looks like it is coming from the crankshaft....thanks for the info..
Old Apr 25, 2004 | 08:10 PM
iam7head's Avatar
oil could be anything, it wouldnt be tough to spot once you get under the car.
you have have a coolant leak and still not overheating. look for a pin size rip/hole on the coolant hose to the heater core or bypass. Mine was leaking once i put on a new radiator cap(the one wouldnt hold any pressure)
Old Apr 26, 2004 | 06:58 AM
FlexW99's Avatar
Default Re: Leaky Accord (iam7head)
weird...my cap is stripped too, very possibly it could be the same thing.
Old Apr 27, 2004 | 09:18 AM
accordSiR94's Avatar
could possibly be a seal. I believe all the 4 cylinder accords that year had a recall on the front balancer shaft seal. Here's a helpfull link for recalls on all makes and models.
http://www.alldata.com/TSB/24/942401A6.html
Old Apr 27, 2004 | 09:31 AM
Accorddrver's Avatar
Default Re: Leaky Accord (accordSiR94)
Cam seal also could be the problem
Old Apr 27, 2004 | 10:04 AM
FlexW99's Avatar
Default Re: Leaky Accord (Accorddrver)
Thanks for the info bros...
LSteggyguy
Jul 9, 2014 08:39 PM
BSmoov83
May 1, 2012 07:41 AM
Silvershadow
Feb 28, 2008 10:50 AM
redbox
Feb 28, 2006 07:16 AM
First Honda 1976
Apr 23, 2004 03:22 PM
