Jumping o2 sensor...is ti bad?
I have a wire ran from the primary o2 to the pin for the secondary and a keep throwing a sec code whats up? SHould i run the second o2?
just run it to the first pin or primary one and no code but ur car will run like *** had my b16 running like this and I was running rich and shitty
so if u don't want a code just wire the first one it should be coo unless the o2 is bad then it will throw a code again
and well I would just run two o2's on any obd0 set up
well if is is throwing a code, i would check your wiring, i ran a wire from my input for my primary O2 sensor to my secondary sensor, and it worked fine, all i did was cut into the wire under the dash and run a swap one to the pin i put in c19, that should work fine
JD95hatch
May 18, 2006 02:51 PM
