NEED ADVICE!!!! Why am I getting a #10 code!!? Is my AIT Bad!?!??
Old Apr 23, 2004 | 07:21 PM
9WON4's Avatar
Default NEED ADVICE!!!! Why am I getting a #10 code!!? Is my AIT Bad!?!??
you heard me!!!!! Please advise me. Is the only real way to guarantee not getting #10 code again is to get a new Air Intake Temp. Sensor????
Old Apr 23, 2004 | 07:28 PM
pdiggitydogg's Avatar
check under dash fuses first
Old Apr 24, 2004 | 05:35 AM
9WON4's Avatar
Default Re: (pdiggitydogg)
thanks for your help, man......but the only one it could be is the alternator/speed sensor fuse.....everything else has absolutley nothing to do with my AIT.
Old Apr 24, 2004 | 05:36 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: NEED ADVICE!!!! Why am I getting a #10 code!!? Is my AIT Bad!?!?? (kidkanedtx)
What year is your car?
Old Apr 24, 2004 | 05:50 AM
Default Re: (kidkanedtx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkanedtx &raquo;</TD></TR><TR><TD CLASS="quote">thanks for your help, man......but the only one it could be is the alternator/speed sensor fuse.....everything else has absolutley nothing to do with my AIT.</TD></TR></TABLE>
Yes, I know
thats the one that you should check
Old Apr 24, 2004 | 05:52 AM
EE_Chris's Avatar
There isn't too much to the IAT circuit.
92-95 Civic: D15 is input; D22 is ground (I would assume this is the same as the 94-97 Teg's as well)
96-98 Civic: D8 is input; D11 is ground
99-00 Civic: C25 is input; C18 is ground
98-99 Teg: D8 is input; D11 is ground
00 Teg: C25 is input; C18 is ground
There are no fuses associated with this circuit too.
Old Apr 24, 2004 | 05:55 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: NEED ADVICE!!!! Why am I getting a #10 code!!? Is my AIT Bad!?!?? (EE_Chris)
My guess would be that a wire has a break somewhere, or a pin has come undone.
I've not seen an actual IAT sensor go bad, but I'm sure it's possible.
Just grab anoter IAT sensor from a salvage engine.
Old Apr 24, 2004 | 06:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
ok
Go out, start the car and pull the alt. fuse
you will throw code 10
(ive done it twice)
Old Apr 24, 2004 | 09:01 AM
EE_Chris's Avatar
Default Re: NEED ADVICE!!!! Why am I getting a #10 code!!? Is my AIT Bad!?!?? (pdiggitydogg)
Don't know what to say to that....I'm going off the Helms ETM and its schematics indiacte no fuses.
What other codes are thrown when you pull this fuse?
Old Apr 24, 2004 | 12:35 PM
it was 2 codes, now that I think of it. It may have been 40 or 42 along with 10
Neither made sense to me as for a reason
Old Apr 24, 2004 | 02:07 PM
DOHCtorTHRUST's Avatar
Default Re: NEED ADVICE!!!! Why am I getting a #10 code!!? Is my AIT Bad!?!?? (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">My guess would be that a wire has a break somewhere, or a pin has come undone.
Just grab anoter IAT sensor from a salvage engine.</TD></TR></TABLE>
mines went bad, just like tom said, just grab another one and replace it. i cant remember if reset my ECU or not. try resetting your ECU after you have switched the sensor.
if that doesnt solve the problem, it must me a wire that came loose somewhere
Old Apr 25, 2004 | 12:20 PM
9WON4's Avatar
Default Re: NEED ADVICE!!!! Why am I getting a #10 code!!? Is my AIT Bad!?!?? (DOHCtorTHRUST)
thanks VERY much for the input, guys......it's a big help.
mostwanted_ek
Apr 25, 2018 03:58 AM
EFRue57
May 29, 2007 11:19 PM
s-tech
Aug 14, 2005 10:04 AM
HCRX311
Jun 7, 2005 11:55 AM
