SOHC VTEC Head swap with D18 block possible?
Old Apr 23, 2004 | 07:03 PM
Radioactive's Avatar
Default SOHC VTEC Head swap with D18 block possible?
Hi all, I would like to know if a SOHC D15 vtec/ D16Z6 head could fit onto a 1992 Integra D18 block. Has anybody tried this? Appreciate all the info and help I can get. Thanks!
Cheers!
Old Apr 23, 2004 | 07:07 PM
Uncle Ben's Avatar
Default Re: SOHC VTEC Head swap with D18 block possible? (Radioactive)
pushes REAL hard..:***** pants:..
I dont know where to start correcting...
Old Apr 23, 2004 | 07:24 PM
Jokerluv's Avatar
do you mean B18? and no
Old Apr 23, 2004 | 07:52 PM
smnowell's Avatar
Default Re: (Jokerluv)
SOHC head will not fit on DOHC block...period.
Old Apr 23, 2004 | 08:28 PM
Airbag Club's Avatar
Default Re: (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">SOHC head will not fit on DOHC block...period.</TD></TR></TABLE>
my friend had a DOHC ZC head on D16A6 SOHC block before. so it *might fit..
Old Apr 23, 2004 | 08:40 PM
mooseknuckle's Avatar
Default Re: (Airbag Club)
fits like a glove.
Old Apr 24, 2004 | 10:10 AM
It's not a B18. A D18 from a 1992-1993 Integra. It's rare but it is around.
Old Apr 24, 2004 | 10:14 AM
barto's Avatar
Default Re: (Radioactive)
are you sure its not d17 that you are talking about? --&gt; DA gsr's?
Old Apr 24, 2004 | 10:17 AM
I believe most D blocks can interchange their heads from DOHC non-VTEC to a SOHC VTEC. Few of my friends have done it with the ZCs. Just wondering if it would also work with the D18 block. It's from a 1992-1993 Integra but the engine is difficult to locate.
Old Apr 24, 2004 | 10:22 AM
mycivicstoo(s)low's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radioactive &raquo;</TD></TR><TR><TD CLASS="quote">I believe most D blocks can interchange their heads from DOHC non-VTEC to a SOHC VTEC. Few of my friends have done it with the ZCs. Just wondering if it would also work with the D18 block. It's from a 1992-1993 Integra but the engine is difficult to locate.</TD></TR></TABLE>ZC's are the exception to the rule, and even then, it's not a simple process.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barto &raquo;</TD></TR><TR><TD CLASS="quote">are you sure its not d17 that you are talking about? --&gt; DA gsr's?</TD></TR></TABLE>That's a B17.
Old Apr 24, 2004 | 10:24 AM
Ignitecivic's Avatar
are u talkin bout the 88-89 integra d16?
Old Apr 24, 2004 | 10:44 AM
Default Re: (barto)
It's definitely a D18. So far I can only mange to find parts for the engine such as clutches : http://www.vantech.com.mx/engl...a.htm
but nothing on the engine specs so far.
Old Apr 24, 2004 | 11:21 AM
Dude, it doesn't exist.
EDIT: Engine info
Old Apr 24, 2004 | 11:26 AM
daklown's Avatar
Dat Dere Cell Tech
Default Re: (mycivicstoo(s)low)
my 1969 integra has a R39 C-tec in it and i put a K45 head on it with a D15 intake manifold and a F22c distributor. hope that helps.
Old Apr 24, 2004 | 12:23 PM
90civichb's Avatar
Default Re: (daklown)
If you can't find specs on the engine, and you can't locate one, why would you even ask?
That looks like it might be a typo for the b18a dohc motor from a DA
Or maybe an even bigger one for the b17 DA GSR
Most of the time people ask when its parts they can actually acquire...
Old Apr 25, 2004 | 12:49 AM
Default Re: (90civichb)
Don't think it's a typo. The early Integras where I'm from are using the D18. The local scrapyards just don't have it in stock but can actually try and get the engine for me in Japan. Need some info on the possibility of a head swap before I actually get the engine.
Old Apr 25, 2004 | 01:21 AM
STREETWERKZ's Avatar
Default Re: (barto)
B17 NOT D17...D17s are in the 2001+ civics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radioactive &raquo;</TD></TR><TR><TD CLASS="quote">It's not a B18. A D18 from a 1992-1993 Integra. It's rare but it is around.</TD></TR></TABLE>
never heard of a D18.... only B18A from 90-93 integras.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radioactive &raquo;</TD></TR><TR><TD CLASS="quote"> The early Integras where I'm from are using the D18. </TD></TR></TABLE>
you being from mexico explains a lot. but there are NO D18's AROUND! EVER, POINT BLANK, If i am wrong, I'll buy the friggan motor, drive to mexico swap the vtec head on for you.
Old Apr 25, 2004 | 01:28 AM
slammed_93_hatch's Avatar
well you wana fuckn help us out and at least tell us were you are from.
in the USA there was NEVER a 1.8 litter SOHC stock from honda.
but in japan some of the lower model DA tegs had a carb'd SOHC motor this could be one of those i dunno
Old Apr 25, 2004 | 04:50 AM
92integra_gs's Avatar
87-89 Integra had ZC D-series on it and 90-93 has B-series on it.. a D18 is definitely a typo or else that engine must had come from out of this planet... FYI the only other engine for the DA Integras are from Japan which are B16s XSI engines... so all in all there are 3 types of engine for 90-93 DA Integras the B17s GSR B18s and JDM B16 XSI... and no dseries SOHC dont fit wid a bseries DOHC longblock...HTH
Old Apr 25, 2004 | 02:51 PM
Default Re: (92integra_gs)
87-89 were not ZC in the US. they were D series. looks similar to DOHC ZC, but not quite.
D18 was a TYPO...you have a B18A and can NOT put a SOHC vtec head on there, put a B16 head on that and end this thread.
Old Apr 25, 2004 | 03:14 PM
Simple SOHC's Avatar
**Grabs head with both hands and slams head into desk real hard**
Awww...much better now...
There is no D18. End of story. Like stated above...90-93 integras only came with "B"18 and "B"17 motors in the US. In japan they also came with...thats right..."B"16 engines. 86-89 Integras came with DOHC "D"-series motors...also know as ZC motors.
Old Apr 25, 2004 | 03:32 PM
rxse7n
Guest
Posts: n/a
Too bad there isnt a d18. I bet it would be cheap...oh well.
Old Apr 25, 2004 | 08:55 PM
Default Re: (rxse7n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rxse7n &raquo;</TD></TR><TR><TD CLASS="quote">Too bad there isnt a d18. I bet it would be cheap...oh well.</TD></TR></TABLE>
That would be some **** there...1.8L SOHC stock. Of course you can make one through JG Engine Dynamics. They have a 1.8L build for D-Series motors...costs an extra 300 or 600 though...making it about 2,600 for built 1.8L D-Series.
Old Apr 25, 2004 | 09:10 PM
H22A EG6's Avatar
actually a guy in the prelude section put a DOHC H23 head on a SOHC F22 block
so it can be done for them but i am sure it wont work for the D to B
Old Apr 26, 2004 | 10:41 PM
just use the D17 block in someones MINI ME swap.
ive always though about running a D series in a track car.
like a FULLY BUILT D series.
BISI can do it.
