880cc precision injector specs
Old Apr 23, 2004 | 02:07 PM
racermike27's Avatar
Default 880cc precision injector specs
Hello,
Does anyone happen to know the specs for a set of precision 880cc injectors.
Like what psi they are rate at and the lb/ft value as well, in any units please. I need these to finish hooking up my AEM EMS
TIA
Mike
Old Apr 23, 2004 | 02:25 PM
FOrSfEd's Avatar
Default Re: 880cc precision injector specs (racermike27)
They are 83.80l b/ft
880/10.5= 83.80
Lee
Old Apr 23, 2004 | 03:58 PM
Alstare's Avatar
Default Re: 880cc precision injector specs (FOrSfEd)
I'm running those injectors aswell, with an AEM EMS...
Here's the battery offset...
http://www.efi101.com/forum/viewtopic.php?t=83
Old Apr 24, 2004 | 01:48 PM
Default Re: 880cc precision injector specs (Alstare)
thanks for the help guys,
for those using the AEM EMS
i am to type 880cc/min and 83.8lb/ft ( how did you get this number? and where does the 10.5 value come from)
correct?
I am going to use the turbo 440 base map what are the specs for these injectors?
any info is appreciated
TIA
mike
Old Apr 24, 2004 | 01:57 PM
FOrSfEd's Avatar
Not sure exactly why thats the actual number that is used but it is.
the formula is
880/10.5=83.80
83.80x80 for the duty cycle=6704
6704/.50=134.08
134.08 is whay eacxh injector can hold.
Multiply tha number by four for how many injectors you have
134.08x4=536.32
Old Apr 24, 2004 | 02:22 PM
kpt4321's Avatar
lb/ft? What the heck?
I presume you really want to know punds per minute of fuel flow. In which case, the standard conversion factor is 10.5. However, since cc/min is a unit of volume flow and lb/min is a unit of weight flow, the conversion depends on the density of the fuel.
They are rated at 43.5 psi, that is the industry standard. Sometimes they say 43, same difference.
Old Apr 24, 2004 | 02:49 PM
FOrSfEd's Avatar
Default Re: (kpt4321)
Thanks for the insight, lol I know how to calculate just not always sure why certain numbers are what they are.
Joeynapp
Jun 26, 2011 03:51 AM
slowwhitehatch
Engine Management and Tuning
Mar 23, 2009 04:28 PM
mchuang
Aug 16, 2005 12:15 PM
m3bluegsr
Jul 7, 2004 07:07 AM
eg2turbo
Feb 22, 2003 10:49 AM
