gettin ready to do my h22 integra.. hows my shopping list look?
Guest
Posts: n/a
:::INTERLUDE SWAP:::
full h22 swap (LSD) Hmotorsonline.com $2800
HCP motor mount kit JDMShit.com $ 270
custom i/h/e & pullies Tony- CO $ 350
HASport axles Hmotorsonline.com $ 350
NGK Iridium Plugs- NGK Wires importrp.com (GB) $ 86
ACT Clutch- XTSS nolimitmotorsport.com(GB) $ 422
Finanza flywheel importhorizon.com (GB) $ 217
GReddy extreme timing belt nopionline.com $ 134
Total: $4629
any help would be appreciated. thanks!
Total: $4629
A good idea would be to stand over your engine bay and go through in your head what you are changing. I know when I did my K swap I over looked a lot of little stuff, such as custom clutch line had to be made. What about radiator stuff? new rad.? new hoses? P/S lines?
Just try and look at your engine, and look at all the small stuff.
Good luck, and it looks like you got a pretty good list going. Im sure you will be just fine.
u said the full swap is coming from Hmotorsonline huh. What year of engine?
I hope u are gettting the firewall mounted map sensor (if its a 92-96) and the injector resistor box with it. Also if u are using the P13 and dont want an EGR check engine light u also need the EGR lift solenoid located in the engine bay. Also fuel line, and the slave cylinder line did not match on mine. I had to have mine custom made. Also depending on how the mount kit mounts u may have clearance issues (like bending the firewall fuel line out of the way of the TPS sensor, and removing brackets on the firewall and such). Also my heater hoses didnt match up or even reach. Definately install those before u put the engine in. They are a bit difficult with the H22A in the way. Good luck.
Enigmatic92
Aug 25, 2008 11:12 AM
Haccordclub
Jul 31, 2007 07:41 PM
if it is adequete.
