Instrument/cluster interchangeable?
Old Apr 23, 2004 | 12:42 PM
-Bionic-'s Avatar
Former Sponsor
Default Instrument/cluster interchangeable?
My tach is messed up and I'm going to replace the cluster. Going on ebay, I notice that all of the clusters are for automatics, while mine is a 5 speed. I was planning on installing reverse gauges, so they would cover the fuel and temp gauge which display N, R, 1, 2 etc.
Does anyone know if there is going to be a problem, when using a cluster for an auto, despite that my car is manual?
Thanks
Old Apr 23, 2004 | 12:55 PM
Monkey Fing a Coconut's Avatar
Default Re: Instrument/cluster interchangeable? (-Bionic-)
instead of replacing the cluster, u can just take the tach out of the new one and put it in ur current one, if u were to replace u would have to register it with the dmv cuz miles would be off and what not, and if u ever decided u wanted to sell ur car most buyers would not once they found out u switched cluters, so just replace the tach, its like 3 screws and no wires, pretty simple
HAccord96's Avatar
I used my stock automatic cluster until someone STOLE it and I bought a manual instrument cluster from a member here, and it worked just like normal. So I would think that you going from a manual to automatic instrument cluster will also be fine.
Old Apr 25, 2004 | 06:44 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: Instrument/cluster interchangeable? (HAccord96)
Thanks for the info guys.
QUOTE=twistedbydezign]so just replace the tach, its like 3 screws and no wires, pretty simple[/QUOTE]
I heard that this is only for the older Accords, while the 6th gen and up don't use screws. How certain are you that the 6th gen tachs are held down using three screws?
Thanks
Ray Satomi
11
Apr 27, 2017 09:05 PM
Voodoo7
11
Mar 25, 2012 05:58 PM
projsectEF
Sep 30, 2006 04:30 AM
diko
Jul 17, 2004 03:22 PM
89DXDann
Jun 4, 2004 11:38 PM
