Stage 3 cams with milled head
Can I do a .030 mill and run crowr stage 3 cams?
Wiseco said that I would need to mill .015 to get the 11.5:1 that I purchaged anyway and so I would like a something close to 12:1 cr.
Munkyw3rkz.webs.com
sure y not! just hand crack it b 4 u start her up!
im running RS cams which are like JUN3's and my head is milled 35thou!
Make sure that its engaged on the VTEC high cam lobes and not the low when you check it or you might switch into VTEC and screw your whole motor.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 »</TD></TR><TR><TD CLASS="quote">Make sure that its engaged on the VTEC high cam lobes and not the low when you check it or you might switch into VTEC and screw your whole motor.</TD></TR></TABLE>
good point!
good point!
1sikhatch
May 13, 2007 04:37 PM
