Milling a H22 Head
Old Apr 23, 2004 | 09:18 AM
93H22ACX's Avatar
Default Milling a H22 Head
How much can you mill (H22A) before you would need to cut the valve reliefs in the pistons?
I will be running wiseco pistons 11.5:1 (with a .015 mill)
Old Apr 23, 2004 | 10:36 AM
PirateMcFred's Avatar
Default Re: Milling a H22 Head (95PRELUDEVTEC206)
Aftermarket pistons have larger reliefs than stock forecasting the use of larger valves and so you will have No problem with a .015" mill. I am running type-s pistons with a .020" mill. I clayed the engine when assembling and I had a lot of room to go too. So no problems yet. HTH
the Pirate
Old Apr 23, 2004 | 11:07 AM
93H22ACX's Avatar
Default Re: Milling a H22 Head (PirateMcFred)
Thanks man!!! would you go 0.030 with crower stage 3's?
Old Apr 23, 2004 | 11:12 AM
DEVIOUS_EG*'s Avatar
stage 3's?.. you might wanna check the clearance's.... be safe.. clay
Old Apr 23, 2004 | 11:51 AM
93H22ACX's Avatar
Default Re: Milling a H22 Head (DEVIOUS_EF*)
yeah i'll clay it first
Old Apr 23, 2004 | 01:08 PM
Rocket's Avatar
You better have some good springs for Crower Stage 3's.
I just saw some the other day and the ramps are ridiculous fast.
Old Apr 23, 2004 | 09:23 PM
ranta18's Avatar
Default Re: Milling a H22 Head (Rocket)
Wouldn't the Crower Spring & Retainer kit work with the Stage 3's?
Brembomaster
Jun 18, 2019 10:53 PM
95accordsir
Mar 9, 2008 09:43 AM
raser5050
Jun 28, 2004 10:30 PM
gaydm.accord
Jun 9, 2004 06:48 AM
juicedh22
Jan 14, 2004 11:15 PM
