DEI 550, 2000 Civic Si, Door Lock Wiring?
Old Apr 23, 2004 | 04:44 AM
1SlowSi's Avatar
Default DEI 550, 2000 Civic Si, Door Lock Wiring?
Hey how you guys doin. I know how to install the easy **** like lights, siren, door trigger ect ect... i just dont know how to wire up the door locks. Can someone tell me which wires from the DEI alarm go to what wires on the factory alarm module? Do i need diodes? Also, how do you bypass the clutch? mine has a relay on it right now, some people have just cut wires and spliced. explain that one... this should be it. thanks!
Old Apr 23, 2004 | 09:10 PM
1SlowSi's Avatar
Default Re: DEI 550, 2000 Civic Si, Door Lock Wiring? (1SlowSi)
bump.. someones gotta know!
Old Apr 23, 2004 | 10:56 PM
hoggy's Avatar
Lock : Grn/wht
unlock: Grn/org
negative pulse in the drivers kick panel
Old Apr 23, 2004 | 11:17 PM
LSP's Avatar
LSP
Default Re: DEI 550, 2000 Civic Si, Door Lock Wiring? (hoggy)
why do you want to bypass the clutch switch? remote start?
Old Apr 24, 2004 | 12:15 AM
1SlowSi's Avatar
Default Re: DEI 550, 2000 Civic Si, Door Lock Wiring? (LSP)
Yeah its for the remote start. I already have a relay installed that bypasses the clutch switch, but i have also seen people just cut a wire and splice to bypass. Just wondering what wires they cut and spliced.
About the door locks, So i just connect 2 wires from the DEI brain to those 2 wires? You say lock/grn white, thats located by the steering column on the factory alarm harness right? And the other other one is way over there by the kick panel? Its not in the same location? thanks for the reply guys.
Old Apr 24, 2004 | 05:25 AM
rjr162's Avatar
you just cut and splice the wire you have relayed to the wire on the other side of the switch (Honda's only use a 2 wire clutch switch, and all the switch does is connect the two wires and allows the car to start)
ussop
Audio / Security / Video
Mar 13, 2015 11:36 PM
redsidriver
Jul 16, 2011 02:49 PM
Pure Sol
Apr 9, 2009 06:10 PM
ketchup_gsr
Oct 29, 2002 08:05 AM
ketchup_gsr
Oct 28, 2002 08:55 PM
