Clear plastic on gauge cluster.
Old Oct 31, 2001 | 05:39 AM
Lynx's Avatar
Default Clear plastic on gauge cluster.
I think this has been covered, but the search turned up nothing for ME. Anyhow, I got some Mequire's vinyl and rubber protectant (Armorall type shiny stuff) on the clear cover to my gauge cluster, and it made the damn thing blurry in spots. It sounds trivial, but everytime, I look at the RPMs, there is this blurry spot near the 7.
Is there any quick fixed to this without replacing the plastic? If my memory serves me right, someone once said to try lemon juice with water, but I don't have a very good memory, so.... help me here if you would.
Thanks
Old Oct 31, 2001 | 05:44 AM
IN VTEC's Avatar
Default Re: Clear plastic on gauge cluster. (WhiteITR)
Isopropyl alcohol or ethanol?
Old Oct 31, 2001 | 05:46 AM
Lynx's Avatar
Default Re: Clear plastic on gauge cluster. (IN VTEC)
Cool, I'll try that when I get the hell out of class. Thanks.
By the way, I'll be back if it doesn't work. Hehe!
Old Oct 31, 2001 | 06:12 AM
betsuni's Avatar
there is a plastic polish you can buy from auto zone, kragen or pep boys. forgot the name though, i'll post again later if i remember.
Old Oct 31, 2001 | 06:46 AM
Yell00ITR's Avatar
Default Re: Clear plastic on gauge cluster. (betsuni)
I would be careful because some chemicals can cause the plastic lense to "craze" or fog up permanently. Just use some water with a touch of car wash soap or dish detergent on a SOFT cloth. Wipe it and it should remove all the gunk from the greasy stuff. After you have removed it, it is more approrpriate to use a plastic polish.
Old Oct 31, 2001 | 08:35 AM
JL 74's Avatar
25 Year Member
Default Re: Clear plastic on gauge cluster. (Yell00ITR)
meguiar's cleaner wax. I did the same thing and I guarantee you it will work.
Old Oct 31, 2001 | 03:55 PM
xtrafastcivic's Avatar
Default Re: Clear plastic on gauge cluster. (jl74)
motorcycle window cleaner works good i don't think that's what it's called but if you go to a motorcycle place they'll have it.
Old Oct 31, 2001 | 04:15 PM
Lynx's Avatar
Default Re: Clear plastic on gauge cluster. (XtraFastCRX)
I think I'll try the Cleaner Wax cause the isoprophyl alocohol did not work. The stuff has been on there for a while. Alcohol would probably work if I had just done it. Thanks for the help boys. I'll let you all know how it turns out tomorrow.
Old Oct 31, 2001 | 04:36 PM
type r 01-1063's Avatar
here's my post a few months ago on the same topic
https://honda-tech.com/zerothread?id=53465
Old Nov 1, 2001 | 08:47 AM
cjb92's Avatar
Default Re: Clear plastic on gauge cluster. (type r 01-1063)
you know I have one, that is in perfect condition. I didn't need it since I put the gauges in my civic. if you want it make an offer
Old Nov 1, 2001 | 12:10 PM
Default Re: Clear plastic on gauge cluster. (superflea)
is for the civic or integra?
Old Nov 1, 2001 | 12:28 PM
cjb92's Avatar
integra
kellogg97rs
Jan 2, 2007 09:58 PM
etp72
Jun 12, 2003 05:51 PM
mattymatt
May 6, 2002 02:07 PM
ITR_MD
May 8, 2001 05:05 AM
