b16a with gsr head...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockb16 »</TD></TR><TR><TD CLASS="quote">as topic says, how much of a difference would it make and is it worth it?</TD></TR></TABLE>
well, you should use a skunk manifold if you plan to try this, but you'll gain some better lowend torque as well as higher compression because of the smaller combustion chamber(s) the GSR head has.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">i heard the B16 works BETTER with the GSR head
and the GSR works BETTER with the B16 head. </TD></TR></TABLE>
well they definitely have their difference, but putting a B16 head on a stock GSR block will lower compression (under 10.0cr) because of the B16's larger combustion chamber area(s). To me, thats NOT better, unless I plan to turbo the engine.
Putting a B16 head on GSR block = poorman's ITR setup (along with changing over to a better piston ala b16 or ITR).
Flowage-wise,
The B16A & ITR head has better top end flow, whereas the B18C heads have better lowend flow.
Flowage-wise,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">you could always WELD the combustion chambers on the B16 head.
you sure could
but the cost effectiveness between getting that done and just running a GSR head comes to play...also depends on the user.
</TD></TR></TABLE>you sure could
