what is code 7 on my 91 civic si with single vtec motor in it
I have an 91 civic si with an single vtec motor but i'm useing the pm6 ecu for now and i'm getting code #7 the trottle angel is that my tpc sensor if hoe do i fix that problemand the check engine light is on also thanks for the help
http://www.phatwhippincrx.20m.com/custom.html
Read the very last paragraph, I dunno if its the same with your motor but I hope it helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant »</TD></TR><TR><TD CLASS="quote">I have an 91 civic si with an single vtec motor but i'm useing the pm6 ecu for now and i'm getting code #7 the trottle angel is that my tpc sensor if hoe do i fix that problemand the check engine light is on also thanks for the help</TD></TR></TABLE>
Your check engine light is on because your computer has thrown the code 7, which is your problem. Either your TPS is broken or needs adjusting.
allm0t0ref
Jan 12, 2007 06:22 PM
