rear engine mount bushing bad on 95 ex??
Old Apr 22, 2004 | 08:09 PM
wisjdmhonda's Avatar
Default rear engine mount bushing bad on 95 ex??
I have a friend with a 95 civic EX with jdm b16a swap and their havin probs with the steering wheel shaking. I think that their rear engine mount is bad (bushing)the engine just seems weird like it is shifting around. the shift linkage is really floppy also. there could be more things worng but this is all i know. any guesses or suggestions about this?? only 3 mounts are used also. thanks
Modified by wisjdmhonda at 1:18 PM 4/23/2004
Old Apr 23, 2004 | 10:16 AM
Default Re: rear engine mount bushing bad on 95 ex?? (wisjdmhonda)
ttt
Old Apr 23, 2004 | 11:07 AM
Evs-One's Avatar
Solbros Owns Me
it's possible....get a new one or some inserts
Old Apr 23, 2004 | 11:59 AM
Default Re: rear engine mount bushing bad on 95 ex?? (Emerika)
Thanks, I'm thinking a energy suspension insert. Anymore suggestions on this problem??
Old Apr 23, 2004 | 12:23 PM
xavior66's Avatar
Could you explain in more detail about the shift linkage flopping around? Like, do you mean the engine's shaking is causing it to flop around, or is it just flopping around on it's own?
Old Apr 23, 2004 | 12:40 PM
EL Vap133's Avatar
Have you inspected the mounts?
Old Apr 23, 2004 | 12:51 PM
Default Re: rear engine mount bushing bad on 95 ex?? (xavior66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xavior66 &raquo;</TD></TR><TR><TD CLASS="quote">Could you explain in more detail about the shift linkage flopping around? Like, do you mean the engine's shaking is causing it to flop around, or is it just flopping around on it's own? </TD></TR></TABLE>
it moves around alot when the gas is pushed and wont stay in 1st gear when the car is off, like some people do when they park.
Old Apr 23, 2004 | 12:52 PM
Default Re: rear engine mount bushing bad on 95 ex?? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Have you inspected the mounts? </TD></TR></TABLE>
The other two engine mounts look ok. the rear one look like it has some wear but it hard to see with all the abs crap in the way.
EJ1_Sleeper
May 11, 2009 09:30 PM
91whiteZCrex
21
Sep 14, 2005 11:33 AM
sol_1320
Jul 11, 2005 12:29 PM
BOMBCRU
12
Jun 28, 2005 01:09 PM
